[Z06] ZO6 LS7 does not run like I think it should HELP
That's obviously really low for an LS7 installed in a Z06. Stock Z's make ~450 RWHP on average. I guess the question is: how much power is that TH400 sucking up, and how much is that non-lock up converter affecting the dyno numbers?
I helped a buddy build a supercharged LS1 that went into his '70 Chevelle. It was an almost identical clone of an engine that I had in a '67 Camaro at the time. Same cubic inches, same cam, same heads. His had a bigger/more efficient blower, though, making about 3 psi more. Both cars on 91 octane + meth.
Even through a TH350 with a 3000 stall, he made 30 RWHP more than my car did with a modern T56 6-speed manual. Both cars had Ford 9" rear ends. Both tuned by the same guy and on the same dyno.
The point of my story? I don't think your drivetrain is sucking up THAT much power. I know a TH400 is worse than a TH350 when it comes to power consumption, but still. Your motor should be a solid 530 RWHP through a manual. For it to make less than 400 RWHP, I'm thinking something is off.
That's pretty darn low for a cammed LS7. I'd almost say try another shop.
First off, if the motor is only putting out ~400RWHP with an auto and given that you have an aerodynamic brick I'd say 127MPH is about right. Was the 127MPH with 433RWHP or 393?
The air intake is likely causing about a 10-15HP drop could be more...you'd just have to straighten it out on the dyno and see...you might be surprised!
I'd really like to see what your logs look like on the dyno (A/F, timing, KR, etc) along with air temps...can you post these? Your motor seems to be way underperforming and before changing anything the base power level needs to come up.
FYI Ive lost 5mph with flowmasters vs spiral flow mufflers on a H/C ls1 fbody.. same night same track put flowmasters on straight off the trailer and went 5mph slower than the previous weekend. Went back to trailer swapped back to spiral flows, went back to staging lanes and picked up the 5mph we lost... Not saying thats your issue as you are WAY down on power but that could be part of the problem.. Can you send me your tune? Even with your aero issues I would expect around 132-134 at your weight.
high stall converter will kill dyno numbers. Doesn't mean the power isn't there. a dyno pull with the converter locked would have given a better representation though. Looser converter = lower numbers.
◦www.youtube.com/watch?v=VByHYImVWEQ
Maybe this will post. I broke a shock on this run. So I backed out on down track. The pass would probably, have been another 10.00. So this will give you guys and idea, on how the truck runs. This is the stock cam.
bada, this will put your mind to ease once and for all to show you how much the Aero is killing you....take a look at the simulation below....I took my 1988 Monte Carlo SS and backfitted the actual track MPH into Quarter Mile Jr to reflect the MPH demonstrated at the track when the motor was all stock with headers and it was only down about 27 RWHP from what it did on the chassis dyno (~460RWHP demonstrated vs 487RWHP on the chassis dyno). My car had 4.10's and a T56. I used this same data and swapped your transmission/convertor, gears, weight and aero date (the aero was just a guess using a van as the aero value) and you can see that your MPH is likely where it needs to be compared to my car....my Monte ran an 11.52 @ 121.66 MPH and what's important here is the MPH, not the ET.
The OP's car looks to be missing almost 150 RWHP. I don't see that just being from the trans/converter setup.
#33
What was the track density altitude on these runs? What rear tire are you using?
I really don't think you are that far off. The dyno numbers are low, but like the others have said its because of the converter. These trucks are poor race cars as the weight distribution is backward and the aero is bad. You might pick up a tenth with a good Powerglide.
#34
#35
#36
http://www.streetsideauto.com/p/moroso-spiral-flow-racing-94051/?utm_source=googlepepla&utm_medium=adwor d&gclid=Cj0KEQiAneujBRDcvL6f5uybhdABEiQA _ojMgoFa8bJg0Z9uKyEQzBYisTrjmET2wYKv9Hfd uHNRcuEaAs1D8P8HAQ
#37
