[Z06] Doing heads soon, should I machine them for higher compression ratio?
#41
I saw no data beyond 7100. It looked like the valve was headed out of control, but without further data unable to determine.
https://www.corvetteforum.com/forums...tte-forum.html
The article says that the combo, Katech Torquer cam and PSI beehive springs, with REV solid exhaust valve, was tested to 7500 RPM.
TEST 5: Katech Torquer cam and PSI beehive springs, with REV solid exhaust valve
Intake valve: Not tested
Exhaust valve: 0.016-in. max bounce at 7,100 rpm; tested up to 7,500 rpm
Katech notes: This combination is not recommended, because valve bounce exceed the 0.15-inch threshold, although the PSI spring did control the REV valve better than did the dual spring.
Read more: http://www.superchevy.com/how-to/140...#ixzz3JxWC8TKt
7500 was the extent to which it was tested, and the maximum bounce observed of .016" came at 7100. That sounds to me like it was gotten back under control after 7100 RPM. At least between 7101 RPM and 7500 RPM.
But what about my other question Mark:
Would you happen to know if the same setup, Torquer cam, same beehive springs but instead with Ferrea hollow stemmed valves which are about 12g lighter than the SS valves used in that link you pointed me to, has ever been shown to demonstrate about the same amount of bounce as the setup in the Superchevy article showed, but at a lower RPM, and below the 7k redline and hence at an earlier onset?
#42
[...] Mark, would you happen to know if the same setup, Torquer cam, same beehive springs but with Ferrea hollow stemmed valves which are about 12g lighter than the SS valves used in that link you point to, has ever been shown to demonstrate about the same amount of bounce, but at a lower RPM, and below the 7k redline and hence at an earlier onset?
Data I've seen indicate the Ferrea hollow is stable to 7700 RPM with the components you specify.
#43
The article says that the combo was tested to 7500 RPM. [...]
5. Torquer cam/PSI springs, solid stainless exhaust valves
INTAKE:
EXHAUST: .014" max bounce @ 6800RPM, tested up to 7100RPM
INTAKE:
#44
The article indicates that the Rev valve was 98g.
I've seen in here the Ferrea hollow stem weighing in at 85g or 86g
So do you consider in excess of .015" of valve bounce to be the point at which a valve is out of control, as the article indicates?
Or put another way, are you saying that if a valve in a setup intended for this engine, reached in excess of .015" of valve bounce, prior to the 7K redline, that you would consider that "stable to 7700 RPM" if the testing went to 7700 RPM?
And also, does the "data" you mention above that you say that you've seen, does it indicate any instances of valve bounce in excess of .015" prior to the 7000 RPM redline? :
"Consideration for when a valve is out of control is subject to debate; however, 0.015-inch of bounce is the basis we use for our recommendations"
Read more: http://www.superchevy.com/how-to/140...#ixzz3Jxbsa2LD
"...valve bounce exceed the 0.015-inch threshold, although the PSI spring did control the REV valve better than did the dual spring..."
Read more: http://www.superchevy.com/how-to/140...#ixzz3JxbewrO0
From that, it seems that .015" is the "threshold" they're using.
That test was run with that particular setup twice. Once for the thread which you linked to, and again for the article in Superchevy.
And the maximum valve bounce, over the course of the 7500 RPM range during which the test was run, occurred at 7100RPM and was measured at .016".
Read more: http://www.superchevy.com/how-to/140...#ixzz3Jxdd0RF7
If bounce had exceeded .016" before 7500 RPM, then they would not have been able to state; "max bounce at 7,100 rpm; tested up to 7,500 rpm".
#45
#46
So in the setup we're referring to with the Ferrea hollow stemmed valves, if valve bounce actually exceeded .015" and at multiple points in the RPM range and prior to redline, you consider that to be an "acceptable" result?
That's a bit different than the criteria used by the author and testers in the Superchevy article.
They recognize a threshold limit of .015" of valve bounce for maintaining control of a valve, and they make no allowance for exceeding that prior to redline.
I'm aware of what you said. But in order for you to say it, I'm starting to get the impression that such a statement would require you to go against the "threshold" that the Superchevy article and the thread you pointed to, state, and would require that you disregard instances of valve bounce at .015", or which would exceed .015", prior to the 7000 RPM redline.
And your argument as to the "relevancy" of the Superchevy author's statements regarding where maximum valve bounce occurred and to what degree, in addition to the maximum RPM tested, well we can let those reading their statements decide.
#47
1. You're trying to put words into the mouths of others who are not here participating in order to create a false dichotomy. This is not logical debate.
2. Your argument is based on a reliance on statements you are trying to parse mightily to create inconsistencies instead of a technical understanding of the data.
Have a nice day
Have a nice day
#48
You have zero data to support your sound. Z.E.R.O.
#49
When I did my heads years ago I milled .030 over bumping me to like an 11.5-6ish with the Katech torquer cam on a 110 - all on 93 octane. I've run this combo for years with 20 degree day drives to work and 100 degree track days. I am very pleased with the results and wouldn't hesitate to do it again the same way. I run my car to 7200, I don't short shift it at all, but I stayed with a new version of the OEM exhaust valve - less weight.
#50
2. Your argument is basedr on a reliance on statements you are trying to parse mightily to create inconsistencies instead of a technical understanding of the data.
And if so, then how would that be any better than the same setup using solid stemmed SS Rev valves and beehive springs which shows no bounce in excess of .015" , the number given was .016", until after redline.
Have a nice day
#51
Agreed. You have constructed a hypothetical which you think will fail.
On what exact occasions and to what extent? Perhaps you should draw a hypothetcal chart with data points so everyone can clearly see what you are conjuring.
#52
Any "occasion" or "occasions" prior to redline, and to any extent beyond .015".
You should be able to answer as to what you consider acceptable valve bounce to be.
And if you're fine with calling excess of .015" prior to redline "acceptable", well then you ought to be able to say yea or nay.
#53
Unless you're saying that their comment:
"Exhaust valve: 0.016-in. max bounce at 7,100 rpm, tested up to 7,500 rpm" is inaccurate, ....... well then you're batting a great big Z.E.R.O with your argument.
They just told you in the Superchevy article with regard to the test #5, that they tested to 7,500 rpm and that maximum bounce, which was .016", came at 7100 rpm during that test.
Now are you disputing that? Are you saying that the maximum was "more than that" in the RPM range that they state? Are you saying that you actually need to see the numbers up to 7500 RPM before you accept that? :
#54
You don't use lack of data to prove an engineering point
#55
OP....shave the heads
I run .030 with the first gen Katech 110 cam on 91 pump here in Arizona.
I even have given thought to milling a bit more and switching to the K501 cam.
I run OEM valves with the Katech supplied PSI springs and retainers.
Just make sure you check and order the appropriate pushrod length.
#56
There is more than that to the equation. This has all been discussed before, so there is need to rehash it again. Go revisit the Spintron thread that got locked, many of your questions are addressed there.
#57
Do you consider valve bounce at, or in excess of .015" prior to the 7000 RPM redline, and on multiple occasions prior to it, to be acceptable for a cylinder head setup intended for use in an LS7 with a stock redline?
A "yes" or "no" will do fine. :
#58
Mark and Quick, enough already. Do you need adult supervision?
I'm fine with good info provided but not the back and forth bickering of "he said, he said".
#59
All this time, the general position among some of us, has been that: "all else equal, a lighter valve will give less valve bounce and hence more desirable results from a valve stability to redline standpoint, than a heavier/stronger valve".
Now, when the prospect of it coming to pass that this is possibly not always the case, and when one of the recently more popular flavor of the month valves might be involved, then every attempt is made to avoid discussing not only that, but any potential implications of that.
So anyone who took that position, might now have some 'splainin to do, if it turned out that way. And they don't want to explain because they can't.
If I'm being told or lead to believe, that an 84-85g hollow stemmed Ferrra valve with a Torquer cam and beehive springs should do better from a valve bounce perspective up to redline because "the valve being used is lighter", than a Torquer cam and beehive springs but with a solid stemmed 98g exhaust valve setup, well then the way I see it, it had better......because if it doesn't, well then what would be the point of using the hollow stemmed, air filled Ferrea valve in the first place? Especially when taking heat transfer capabilities into account.
In such a scenario and if this were the case, then not only would you not see any benefit whatsoever from a prevention of valve bounce below redline perspective, in fact it might even work to your detriment, but you would be taking on potential heat transfer issues to boot. And for what??? : Because someone insisted that because they are "lighter", then automatically they must be "better"????
That would not be good for those who have touted these valves over the solid SS valves for the longest now.
What happens to the "lighter valve is always better, all else equal" position, reinforced in here for a long time now, if this is the case?
That's right. It won't hold up.
And it may turn out that it was the efforts some of the more staunch believers in here in that position, that potentially end up actually undermining that position.
Take a look at Test #5 Dave. What do you see???
Ask Mark up front, have him answer with no BS, and no hemming and hawing, just straight up, if setup #5 did any better or worse below redline, and especially just prior to and AT redline, (and both you and Mark, can see how it did below redline here by looking at the peach colored line in the graph showing exhaust valve bounce), using the Ferrea valve in place of the Rev SS valve which was used in test #5 of the link I gave you just now.
You look at that peach colored line in the graph of the first post Dave, here and you don't see the "threshold figure" that everyone in here talks about since the spintron craze of .015" of valve bounce, until you cross over into 7100 RPM.
Ask him if the same is true with the same setup, but instead using Ferrea hollow stemmed valves, or if you would actually see of .015" of bounce before redline with such a setup using Ferrea hollow stem valves and using the same Torquer cam and beehive springs.
