Carbotech brake pads coupon z28
#361
Supporting Vendor
St. Jude Donor '11,'13
what would you consider the step up for street use? I have the 1521 on my z06 and find myself wanting more initial bite and overall stopping power. I was looking at running the AX6 or a combo of XP8/XP10. I can live with some noise/dust as the z06 isn't my daily driver. I was a little concerned that the XP8/10 wouldn't have enough cold bite. thanks
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#362
Supporting Vendor
Ok I would skip the AX6 and go to XP8 on front and rear. This will give you plenty of bite on the street with no issue at the strip can be tracked and Auto X. XP8 is less dust and noise than the AX6. The AX6 is really a dedicated Auto X pad. Give me a call at 216-780-8825 and I will get you set up. If you are not really planning on track days leave the 1521 in the rear and just get a set of XP8 fronts you will have no issue with that set up as well.
#365
Supporting Vendor
Give me a call at 216-780-8825. If you have no questions and know what you need order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#366
Supporting Vendor
We offer 100% made in the USA performance brake pads from Carbotech.. Order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$
Amp’D Autosport.com
PH:216-780-8825.
Check out Promo code:z28.
Amp’D Autosport.com
PH:216-780-8825.
#367
Supporting Vendor
To the top Tuesday.. Give me a call at 216-780-8825. All Carbotech compounds ready to go!. If you have no questions and know what you need order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#368
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#369
Supporting Vendor
I can save you $$ on Carbotech brake pads. Email , PM, Leave message here or call direct at 216-780-8825. All pads available on line @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#370
Supporting Vendor
To the top.... Use promo code z28 @ check out and save $$ or just call us direct at 216-780-8825 and you can save $$.. We can also send pay pal..
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#371
Supporting Vendor
Open Saturday for QUESTIONS and of course ORDERS... Give me a call at 216-780-8825. If you have no questions and know what you need, order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#372
Supporting Vendor
Order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#373
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#374
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#375
Supporting Vendor
Contact me for best deals on Carbotech brake pads.. Email , PM, Leave message here or call direct at 216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#376
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#377
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#378
Supporting Vendor
Brake Pads Street or Track Amp’D autosport has plenty of Carbotech compounds ready to go. Take 5% off your order when using promo code z28 at check out or call us direct at 216-780-8825 to order. Pre bed option is also now available for all Carbotech AX and XP series brake pads. Looking forward to hearing from you soon. Please call or email us with any questions.
Direct ordering http://ampdautosport.com/brake-pads/corvette/
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#379
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#380
Supporting Vendor
Give us a call 216-780-8825 and we can recommend the compounds that will be perfect for your front and rear pads. Assuring that they perform together with optimum effectiveness
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
