Carbotech brake pads coupon z28
#441
Supporting Vendor
St. Jude Donor '11,'13
I offer great customer service with great pricing on one of the best aftermarket pads available for your Corvette. Let me know what your driving style entails and I will recommend the best set up for your driving application. I can be reached by Email, PM, Leave message here or call direct anytime at 216-780-8825. All pads available on line @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$ if you know what you need.
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#442
Supporting Vendor
Here is all compounds we offer from Carbotech performance brakes.http://ampdautosport.com/compounds/
Amp’D Autosport.com
PH:216-780-8825.
Check out Promo code:z28.
Adam Adelstein
PH 216-780-8825
Fax 216-331-1531
Email adam@ctbrakes.com
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
PH 216-780-8825
Fax 216-331-1531
#443
Supporting Vendor
Give us a call TODAY 216-780-8825 or order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#444
Supporting Vendor
Thank you all for the orders we appreciate it. Keep the phone calls, Emails, and PM’s coming we appreciate the opportunity to work with all of you. We are open until 9PM Monday through Thursday. Friday and Saturday until 6PM and always 24/7 at http://ampdautosport.com/brake-pads/corvette/ use promo code z28 at check out to receive your forum discount.
Amp’D Autosport.com
PH:216-780-8825.
Amp’D Autosport.com
PH:216-780-8825.
#445
Supporting Vendor
Order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#446
Supporting Vendor
From low dust to full out race pads we have all Carbotech compounds ready to go. Let me know what your driving style entails and I will recommend the best set up for your driving application. I can be reached by Email, PM, Leave message here or call direct anytime at 216-780-8825. All pads available on line @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$ if you know what you need.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#447
Supporting Vendor
Happy Monday..
Amp’D Autosport.com
PH:216-780-8825.
Amp’D Autosport.com
PH:216-780-8825.
#448
Supporting Vendor
Thank you all for the orders we appreciate it. We are open until 9PM Monday through Thursday. Friday and Saturday until 6PM and always 24/7 at http://ampdautosport.com/brake-pads/corvette/ use promo code z28 at check out to receive your forum discount.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#449
Supporting Vendor
Happy Friday end of the month deals..
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#450
Supporting Vendor
End of the month deals.. What are you looking for?
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#451
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#452
Supporting Vendor
Happy Friday save 5% on your order use promo code z28 at check out or call us direct at 216-780-8825. If you have questions leave them here or feel free to call me at 216-780-8825, email or send private message.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#453
Supporting Vendor
Open Saturday give us a call 216-780-8825 or order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save $$
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#454
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#455
Supporting Vendor
1 piece install http://www.101corvetteprojects.com/2...rvette-c6-z06/
We have finished our redesign of our C6 Z06 One Piece pad for the front and rear stock calipers (PBR Calipers). We were the first to release the padlets almost four years ago, and then we were the first to release the One Piece over a year ago. That design that we worked with GM on wasn't perfect. That's the same design you see other companies using now.
We set out to redesign the new One Piece all on our own. We wanted to make sure it was perfect and even more user friendly. This new design will drop right into the caliper and you don't have to take out the caliper pins or spring clips. The spring clips are critical in keeping the brake pad square to the rotor surface and ensuring that the pads slide smoothly along the pins. The spring clips also assist in reducing the noise inside the caliper.
This new one piece will make changing pads a lot faster and easier. The newly designed Carbotech One Piece will give longer pad life and a little more bite as well. We are molding the new One Piece pad just like we do with all the C6, C5, and C4 brake pads.
We are also using industry leading NRS technology. If you're not familiar with NRS technology it gives molded pads up to 8 times stronger sheer strength vs. conventional molded brake pads and riveted pads. NRS technology also helps in reducing noise and vibration of the brake pad inside the caliper as well as aiding in longer wearing pads. We use NRS technology on all C6 & C5 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
#456
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#457
Supporting Vendor
Open Saturday for QUESTIONS and of course ORDERS... Give me a call at 216-780-8825. If you have no questions and know what you need, order direct 24/7 @ http://ampdautosport.com/brake-pads/corvette/ Use promo code z28 at check out and save 5%.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#458
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#459
Supporting Vendor
We offer the highest customer service along with the highest quality brake pad on the market for your Corvette. We can give you the best prices on Carbotech brake pads leave a message, Email, PM or call us direct at 216-780-8825 for pricing and your application.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#460
Supporting Vendor
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
