C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Recommendations when buying a used z06?
Old 12-19-2014, 02:17 PM
paloalto00
paloalto00's Avatar
Default Recommendations when buying a used z06?
I've been looking around for quite awhile, but have yet to pull the trigger. There's several good deals on higher mileage z06s` but am worried about the dreaded valve dropping issue.
I know there are several warranties available for purchase, but it still doesn't put my mind at ease that my engine can blow up in the middle of a drive.
What would you lads recommend doing first when purchasing a used Z?
Old 12-19-2014, 02:39 PM
banipal19
banipal19's Avatar
Valve issue could happen to any LS7 even less than 5K miles. I just bought a Z06 with 7K miles on it. After driving it for 2K, I did the wiggle test and the guides are completely shot! The very first thing you should do is get the heads checked and get them fixed if needed.
Other than that, Z06 is an amazing car from every aspect!! Great DD and a BEAST in performance! Even with the valve issue, I still love it and wouldn't trade it for anything!
Old 12-19-2014, 02:40 PM
GunnerSMG
GunnerSMG's Avatar
Factor in the cost of getting your heads redone into your total cost of the car. Get them fixed and never worried about it again. Done
Old 12-19-2014, 02:48 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
$1000-3000 depending on what you want and if you do it yourself or pay someone.
Old 12-19-2014, 02:49 PM
GunnerSMG
GunnerSMG's Avatar
What's a rough estimate to have them done? I don't plan on racing the car anytime soon, but it would be a waste not to track the bad boy
Well...... there are lots of ways/places to go on getting the heads redone. I would do a search of the forum and check the threads on this issue (there are many). I personally went with WCCH and installed them myself. I think the heads are about $1700 for the work and then say at a shop $1000+ for the labor.
Old 12-19-2014, 03:38 PM
Unreal
Unreal's Avatar
$1700 is for a performance ported package. Actual guides/etc is ~700-900 so if you aren't doing a perfomance upgrade you can just do that. Add gaskets, bolts, fluids and you can do it yourself for $1000.
Old 12-19-2014, 04:52 PM
v8sten
v8sten's Avatar
you can be like me and find a car with it already done
Old 12-19-2014, 10:08 PM
reasonable suspicion
reasonable suspicion's Avatar
Dont even bother doing a wiggle test. Just get the heads done. I would budget 5K if you arent going to do the work yourself.
Old 12-19-2014, 11:09 PM
79inSD
79inSD's Avatar
This is what I did. For me history was more important, I got a one owner car where all work was done at LG. They knew and confirmed the car history as well. I bought it sight unseen and had LG do the heads and ship the car to me. Been loving it ever since!
Old 12-20-2014, 06:46 AM
tim414
tim414's Avatar
St. Jude Donor '12
One more question guys, if I buy a higher miled z06. Would an engine rebuild benefit me?
Too many unknowns. Generally speaking, no, not if it's been driven normally/maintained properly. Get the guides checked though.
Old 12-20-2014, 09:30 AM
MUKAK
MUKAK's Avatar
Even over 100k miles? Also, do you think they would let me take the car to a mechanic BEFORE purchasing?
in post 14 you said your friend runs a LS shop and your pops is a mechanic and you asking this forum if you should take it to a mechanic??
I'm indeed in no rush, I notice the prices going lower and lower and it's just putting me in a better position. There is actually a LS engine shop near where I live that my friend's dad runs also my dad is a mechanic.
I have a question about the front splitter, I see some that look crooked on one side, is this something to be worried about?
Yep, depreciating assets depreciate. You aren't looking to purchase a ford gt. Hell, wait two, three more years and the prices will be even lower.
No matter how many miles have the heads done. I wouldn't worry about rebuilding the entire engine.
If a dealer or private party won't let you get a PPI, then look elsewhere.
To Recommendations when buying a used z06?
Quick Reply: [Z06] Recommendations when buying a used z06?
