[Z06] C6 z06 do your tires rub fenders when turned all the way?
More info needed. The stock wheels and tire sizes do not rub at factory ride height and I have not heard of them rubbing on cars lowered on OEM bolts. It could be possible to align the suspension in a way to get rub, but not at factory or street specs.
I've had 295/35 fronts rub lightly in a couple of places (full lock on the brake cooling ducts) and 335/30 rears on the top fender liner, lightly.
The front tires do "skip" or skid at parking lot speeds at full steering wheel lock, but that is inherent in the summer wide tires and the Vette suspension. They do that without rub, especially in cold weather. Maybe that's what you are experiencing?
Do you know what your alignment is? Close to stock?
It rubs on the inner side. I'm pretty sure it's the liner. Not sure about the alignment, I just bought the car a few months ago with a clean car fax.
Rub would be to strong of a word but I can see where my front tire has just kissed the front part of the front fender liner/trim . My car is stock ,not lowered with factory tires and wheels . 19/20 package , I can take some pic's if you need me to.
I have a touch of rubbing on the brake ducts, but only with my 315 section width Hoosiers on the car. I have a very aggressive alignment (lots of negative camber and lots of positive caster), and the car has a mild amount of lowering on the stock bolts. 18"/19" stock sized wheels on the car.
Even with that set up, no rubbing with the stock sized Bridgestones or Michelins.
Received 8,928 Likes
The most likely place for the wheel to rub on the inside is the brake duct. If you are turning hard left the right front wheel comes very close to the right brake duct so if there is any variation in size or offset the tire may rub on the duct. Turn your wheels so they are pointed out of the wheel well and then use a flashlight to look inside the wheel well and see if the brake duct has an arced groove in it.
Bill
Stock 2011 Z07...19's on the front and they will rub on the inner fender liner on a hard lock turn either way...others equipped the same way have had the same issue.
My stock 2011 Z07 does not rub. The front tires "skip" across the pavement at low speeds when turned full left or right.
