[Z06] Changing battery in my 2009 c6z
I am changing the battery Will I need to do anything with the tpms system? Reset etc etc.
How long will the batteries in the tpms sensors last ?
I some how ended up with something like this made a long time ago, uses what I guess is reject vbelt material for the strap. One of the best tools I have.
http://www.oreillyauto.com/site/c/de...2353&ppt=C0005
I got the AutoZone Gold Battery for my 09Z a couple months ago and am pleased with it.
Tips:
Get a battery strap ($4-5) to pull out the OEM battery as the battery gets hung up on the disconnected cables and the battery box lip unless you really enjoy getting your knuckles bloody. The new AZ battery will have a small strap and the factory battery retainer strap works fine. The AZ battery has a vent in the proper place to hold the OEM vent tube.
If you have a small trickle charger that will plug into the lighter plug, use that and you won't lose any of your settings.
While the battery is out, tape the bottom end of the tie down posts so they don't slip out of the holes, it will save you fishing time.
Tips:
Guys, thanks for the advice. Much appreciated!
I let my battery die last winter and the window would not roll up all the way after recharging it for about two days. What do you all mean by re indexing the window?
just changed mine and only had to re-index the windows, radio and all settings were not affected. Battery strap is definately needed, or strong duct tape to make a handle.
Moderator
After changing the battery, start the car and pull up on each window button 3 times and hold for a few seconds. Do that twice for each side and they will re-index.
