[Z06] Need Comp Cam Lifter Part Number
Looking to replace my stock LS7 lifters, anyone know what is the direct replacement from Comp Cam, also will it require a different push rod length? I am going to fix my heads (leave everything stock) but change out lifters when I do the heads. Thanks
Shhhhhhh
Give you a free secret to a quieter valve train. COPO lifters!!!!!
Thanks for the info, but need part number for OEM style replacement from Comp Cam? I see two listed on Summit but do not know the difference between 850 or the 875? Thanks
Don't see many people recommending or using comp cam lifters. I would look at BTR, Johnson, Crane, Lunati, Morel and other high quality lifters.
