View Poll Results: Which Vendor?
Multiple Choice Poll. Voters: 141. You may not vote on this poll
[Z06] WCCH v American Heritage
You can't really say too much about WCCH in here, as they are a non forum vendor.
However be advised that they do much of the cylinder head work for Katech, and have probably done more LS7 cylinder head rebuilds than any other outfit in the country, and that might influence your own decision.
Good luck.
Good luck.
Good luck.
Years ago (~15k) I had WCCH do my heads with the katech formula, bronze guides, new OEM exhaust valves, Katech ti mo intakes, ti retainers, and psi springs (also milled .030 and had a port and polish done). Has been great and held 546 rwhp for years of commuting, drag, track, dyno and street pulls. I imagine had I used AH I would have had the same experience.
Decide what you want done, price them both out along with how long it will take each to turn around and get back to you. Something to note, AH is a sponsor on here and WCCH is not. I would probably use AH if I did it again as they support the folks on this very forum.
You can't go wrong with either place, I lean towards Kohle because he uses harder p.m. guides and lightweight components and he hand ports his heads but again they're both great guys to work with.
With constant bombardment of posts from "the usual suspects" (already present in this new-born thread), why in the world would WCCH bother to spend the money - nothing beats free!
When WCCH is constantly busy working in machine shop, why come on here to acknowledge all the engineering and mechanical expertise (satire) on this forum! Most people have already made up there minds anyway on the solution that meets the needs of there thought process...
My Father in Law and I both went with American Heritage based upon my research and I did a lot of it before I pulled the trigger. Picking up both of our cars this Saturday.
I spoke with WCCH, American Heritage, and others on the phone before I chose which vendor, I recommend you do the same and you will probably go with American Heritage after you talk with Kohle.
I like the why behind how he does the heads, using harder PM Guides vs. softer Bronze (which Richard from WCCH said he likes PM better than bronze, but cannot source them), the Ferrea Valves which combined with the PSI Springs & Titanium Retainers keep the weight similar to the stock exhaust valve setup. I think the heavy Stainless Steel Valves that WCCH uses is way too heavy for the valve train in my opinion. American Heritage uses quality machines to do the guide work (Newen Contour BB and/or a Serdi 4.0), then bead blasting, re-surfacing the heads, just flat out quality work. He has been a Certified Machinist for 15 years, so he knows what he is doing and also has one of the best LS Mechanics Edwin working for him in the shop.
Read my review and others on the forum:
https://www.corvetteforum.com/forums...ce-review.html
Here are the pictures of both of our Z's heads that were just completed.
WCCH is a great shop. They have done work for me on many of my applications. I disagree with the recommendation that WCCH suggests to address the LS7 head but I know more about them than AH. If I had to make a decisions between one or the other right now for my LS7 I would use WCCH and just tell them what I want done. Just like Katech does.
WCCH is a great shop. They have done work for me on many of my applications. I disagree with the recommendation that WCCH suggests to address the LS7 head but I know more about them than AH. If I had to make a decisions between one or the other right now I would use WCCH and just tell them what I want done. Just like Katech does.
What were the applications you used WCCH for if you don't mind me asking?
thanks,...
Had my heads done by Richard at WCCH after I researched the other shops. He has a national reputation as the go to shop from motorcycles to full blown race cars. I'm pretty sure he has been doing heads for over 20 years and all he does is heads !!
I did a walk through pictorial of his shop a couple years back if you want to search this forum for it.
DH
DH
DH
I have had nothing but good experiences with WCCH. Had about 20-25 sets of LS7 heads alone done there. Applications range from street to drag to road course. Main differences in those apps is cam design
They look really good, time will tell if my choice was the right one. I have no worries.
