[Z06] How Much of Car to cover with 3M or XPEL?
I see some guys have done the ENTIRE car with the protectant,which I am hesitant to do as I feel the gaurd doesn't shine as well as the paint (I have a black car). The picture is from another thread that discussed problem spots on the wide body cars as far as rock chips go. I only want to do the problem areas of the car with the gaurd,I am looking for some pictures of this partial covering having been done-does it look OK splitting the panel-part covered part not, without it being on a body line? Some pics of this done if there are any would be great. Thanks Rich
Think about everything that can be directly impacted as you're driving. Such as the Front Bumper, Headlights and Fogs, Mirrors, Rear Brake Cooling Ducts. I also have a piece installed in the door opening pockets. The Rocker Panels (wrap completely underneath).
John
John
Received 8,930 Likes
I use collision wrap when on the track. It is a product similar to the ones you mentioned although only 3 mils thick and is considered a temporary covering. Wrap from the front wheel well all the way to the rear wheel well opening. On the door you don't really need to go any higher than the crease although doing the mirrors isn't a bad idea. On the rear quarter it is a good idea to take the covering to a spot 3 or 4 inches above the center of the wheel. When I run on the track I find black smears from track turds thrown by the front tires on top of the rear wheel opening a couple of inches above the edge. I use the wrap on the front fascia since there is so much stuff thrown by other cars on the track but I don't use anything on the street or highway. I haven't had any real damage on a front fascia since I hit a box end wrench that fell off a truck back in 1990. That put a nice broken paint circle on the front fascia of my 86.
Bill
Bill
I had the areas you show covered, along with the rockers, 1/4 way up the doors, the mirrors, entire front and 1/3 way up the hood.
Mine was done in Expel when I bought the car new in 2010 and it still looks perfect. My car is Cyber Gray, so it's a dark color too and you can barely see the difference in shine between the paint and covered areas...Just take good care in cleaning, and you'll be super happy! I have Zero paint chips on the covered areas!! Be sure to get a great installer for the work!!
