[Z06] Rear trunk lid problem
Hello corvette nation ., I'm having a problem with the weather strip between the rear window and beginning of roof., the seal is instructing probably from rubbing with hatch when opening and closing ., does anybody know what I can do to repair or replace this seal?
I'm having the same problem. In the colder months, it seems to get pretty bad.The weather stripping is actually folding under the rear glass when closed now. Hopefully someone has a permanent solution to this. Last time it happened, I pulled the weather strip to the proper position and placed a piece of masking tape around it (all the way around the seal and into the trunk area) and then closed the hatch on it. Left it like that for a couple days and then pulled the tape off. The seal was okay for a while after that.
