[Z06] When to replace Oil pump?
Not sure if my question makes any sense, but is there a way to determine when to replace/change oil pump before it goes bad causes and causes engine damage.
My first z06 motor spun a bearing due to oil pump failure. The only symptom was low oil pressure, but the engine had already failed by then.
Just recently I did head and cam on my second motor after about 35K miles on that motor and I kept my stock oil pump.
Should I have replaced or upgraded my oil pump? How often do the oil pump fail espeically after 35K miles on the motor?
"My first z06 motor spun a bearing due to oil pump failure. The only symptom was low oil pressure, but the engine had already failed by then."
Well if the damage happened before the drop in oil pressure then it wasn't the pumps fault. When you have a major bearing failure, you end up with extra clearance where the bearing used to be with less restriction to oil flow. No restriction means no way to make pressure. Same thing with high milage engines. As a engines bearings naturally wear you end up with additional clearance and less restriction to flow and lower oil pressure.
Not saying that pumps don't wear out but not in 35K miles unless something else came apart and damaged the pump
If the pressure indicates a pump that's operating as per design, leave it alone.
Often, unneeded maintenance adds more risk than it removes. Unnecessary disassembly, contamination, installation error, etc.
It seems avg oil pressure went up by like 8psi throughout the RPM range.
Is that normal?
