[Z06] ALERT !!! Do You Have Fairy Dust In Your Oil ??
#221
blackstone said poor wear from exhaust valves on my last report but i just had heads replaced not long ago under warranty. i can cut my filter open tomorrow. Do you have high levels of iron? If you check my post history you'll see my BS reports. man i probably hold the record for the highest iron level but what can you do. Local chevy dealers probably won't do anything unless something blows.
#222
UOA from the car. No wear metals are jumping out at me. Possible that the particles are too large to show up in the UOA. I'm going to pull the comp trunions as soon as I can to try and eliminate that as the source. I'm still not convinced that the flakes aren't coming from the catch can itself.
#223
I changed my oil last week and should have a new Blackstone in a few days. I will post it.
And I did have some dust at bottom of can again. Probably did a couple of times ago too and just didn't notice it. But its not a lot.
Also my magnetic drain plugs are very clean compared to my previous Z06 with just a tiny bit of sludge but not particles at all.
DH
#224
How much did you drain out from the HPDE's?
#226
That's good, stock or HCI I got close to 4 ounces in 70 miles at HPDE, with mostly 4-7K running, but less than an ounce in 2-3K street running.
#228
DH
#229
if you have chrome, right click and view the image in a new tab, you'll see the picture in full resolution. Even though my catch can is black it was hard to get a good picture of the metals inside.
#230
DH
