[Z06] 2009 Z Cam and header upgrade
Sent my 2009Z to Vector Motorsports for 1-7/8" Kooks and cam swap. Going with a .655/.658 lift and 231/247 duration at .050. Car had baseline of 442RWHP stock with Halltech CAI and Corsa exhaust. Looking to make around 530 RWHP. Had a year left on warranty but could wait no longer. Just need the snow to go. Enough already here in Michigan.
I assume you are replacing valve springs for this new cam? I would insist on doing a "wiggle test" on all the valve guides.
The link below is an article on a low mileage 2012 Z06 that had valve guide issues. The NEW replacement cylinder head was worse than the used head they took off.
http://www.corvetteactioncenter.com/...-engine18.html
Best of luck!
Best of luck!
Best of luck!
Best of luck!
Thanks for the input!
If you just want 530rwhp I would have done a smaller cam. That is a solid 550+rwhp cam.
