[Z06] LS7 Valve Guide Check
#41
Received 8,928 Likes
He will do the bronze guides as soon as the new heads are here and be ready to assemble everything when the valves show up. If they get there in the 2.5 week time frame I will have just enough time to change the brake rotors, put in track pads, bleed the brakes and get the wheel alignment done before I put the car on the trailer.
He has offered to let me put the race seats in the car while it is sitting in the shop if I want to do that.
Bill
#42
Here is my story as of tonight. First off I've owned my Z now for... Almost a month. I love every sec I have behind the wheel. She has 47k miles and the motor has never had a wrench on her until tonight. That being said she has been babied all 47k of those miles. I'm aware of all these valve issues even prior to buying the car. Honestly I don't care. My plan from day one even before signing the papers at the bank was to replace the heads. So within the first days of owning her I order a set of BR7's from Brodix. Now a month later and Brodix taking a long a$s time I decided to do my own "wiggle test" for peace of mine to my noticeably louder tick to the motor. So I ventured out to the garage with my gimped hand (story behind that) to see this for myself. I pulled both valve covers and rockers.
Peace of mind knowing I didn't fall victim to the needle bearing issue or a damaged valve. After removing each rocker one at a time I used my calibrated Frankenstein hand to check for movement. Note I have 9 stiches in my hand so I wasn't using my Hercules power for check for movement.
Out of all 16 valves I found most moved a little. The deal breaker was on 2 of the intake valves #3 and #4 had lots of play. #1 #2 #5 #8 very little play and #7 and #6 had no play. I may self proclaim myself as a genus but cant give you a dial gauge number from my fingers. The 9 stiches could have cause the miss calibration in numbers so I figured I wouldn't lie. Morel of the story is loose is loose and tight is tight. There was a difference between each valve which is enough for me to "ground" the vette till the new heads show up. Im a week out from getting the Brodix so I wont break my heart watching her sleep till then. Minus the minor damage discovered to the top of one of the valve caps she was good on the inside.
This gives me that warm and fuzzy knowing I wont have to open up the lower end looking for missing parts or bearings. Ill post the progress on the Brodix heads when they show up. Cheers.
P.S. Incase you wondered the 9 stiches came from one of my other projects I'm doing. Building 2 LT1 300hp corvette motors for my boat. Yes Corvette motors as in 100% to spec. Short of cast numbers they will be legit in every way. Only thing missing is a transmission and car attached to them. Ill post that project once there done.
#43
ttt
Updated first post.
Updated first post.
#44
Shear, tensile, flexural, compressive, any and all stress on an object is directly impacted by the cross sectional area of the material involved and the force applied.
For an equal force, greater area will mean less stress on the object.
stress = force/area
Hollow - less material cross-sectional area, solid - more material cross-sectional area.
This doesn't even consider the the difference in loading dynamics on the exhaust valve compared to an intake valve based simply on when/how it opens during the combustion cycle.
EDIT: That's why I'm not particularly surprised intake valves would tend to survive longer than the exhausts.
#45
Right, and it seems possible that in an "in-spec" setup (proper guide clearances, decent rocker wipe, tune not leaned out, proper valve seat location, no significant deviations in the exhaust valve wall thickness) the OEM exhaust valves are okay...but often it seems like one or more of those items are out of spec to varying degrees.
Though I am interested on hearing Michael D's theory on the head cooling design.
#46
Is that correct or did I miss part of the story?
#47
Congrats!
#48
I think they just gave him new cylinder heads and did not cover the labor... My heads are being pulled as we speak with 47k miles. We shall see if GMPP will give me any help...
#49
Bill
