[Z06] Need head/cam advise on my first build!!!
Hey everyone, this is my first post here as well as my first Corvette. I have a 2008 Z06 bone stock. I am taking it to my local shop that after I explained what I wanted came back with this:
-wcch fully cnc port ls7 heads / includes polish intake valves, stainless exhaust valves, mill and assemble w/bronze valve guides.
-katech torquer ls7 cam
-prc dual spring kit
-katech c5r timing chain
-gm head gasket
-arp head stud kit
-gm front timing cover gasket
-gm lifter guide tray
-gm balancer bolt
-gm front main seal
-160 degree thermostat
-arh 1 7/8 headers 3x3 x-pipe with high flow cats
-vararam cai
-b&b bullet exhaust.
-All Installed, tuned, dynoed
Now I have watched many videos of the katech torquer cam and i just don't like the monotonoeus sound it produces. I love the sound the lingenfelter gt19 produces. I do not want a big cam at all either. I also looked at the Livernois cams but it just doesn't seem that there small ones put out a lot of power. If I were to change to the gt19 cam, besides the springs that I would have to change to the ferrea springs they demand what else should I change? Is the WCCH heads better then the lingenfelter heads as lingenfelter does not use bronze guides but sintered iron? Any advise would be great as this shop pretty much does all its builds with Katech Cams and WCCH heads.
AND yes i spelled advice wrong and cannot figure out how to edit it. Sorry about that.
-gm head gasket
-arp head stud kit
-gm balancer bolt
-gm front main seal
-vararam cai
Might want to replicate this setup, made 600 WHP:
Gizmo5 on here had American Heritage Performance build his car recently, he got the final tuning done today and put down exactly 600 WHP with the mods below:
American Heritage Performance Package 4 Heads + Upgrades
- Disassemble and Assembly of LS7 cylinder heads
- Performance Valve Job
- Resurface Heads .20 if possible with cam (letting Kohle do the math on that)
- Clean and Bead Blast Entire Head
- AHP Powdered Metal Valve Guides (Very happy with Data provided)
- Stock Titanium Intake Valves Treated/Tumble Polished (sent to DelWest for treatment)
- Ferrea Competition Plus Hollow Stem Exhaust Valves F2042P
- 3/8 Hardened Chromoly Pushrods
- New Viton Valve Seals and machined valve locks
- GMPP LS7 Lifters and Lifter Trays
- GMPP LS7 MLS Head Gasket Set
- GMPP LS7 MLS Exhaust Manifold Gasket Set
- ARP LS7 Head Bolts and Crank Bolt
- AHP Hand Port/Polish of Heads
Cam Setup:
- BTR Cam 231/242 .653"/.627" 112+2
- BTR .660 Dual Spring Platinum Kit with Titanium Retainers
Supporting parts to bring it all together:
- Kooks 1 7/8 Headers w/ Kooks 3" catless Mid Pipe
- AHP Hand Ported/Polished Throttle Body
- Peaks Speed Shop Ported Intake Manifold
- Halltech Super Bee MF103 Intake
- TR6 Spark Plugs with New Performance Wires
https://www.corvetteforum.com/forums...excited-6.html
Tuned by Shawn Church at Church Automotive Testing
Lastly here is how it sounds after it's all said and done:
Cam Setup:
-gm head gasket
-arp head stud kit
-gm balancer bolt
-gm front main seal
-vararam cai
-gm head gasket
-arp head stud kit
-gm balancer bolt
-gm front main seal
-vararam cai
Pretty good list of parts in my opinion. Only things I'd change are the springs for BTR or PSI, depending on what cam you go with and I'd just get arp head bolts instead of studs. Also, if you are concerenced with long term durability you might want to find some harder powdered metal guides. Ferrea hollow valves might be worth considering too.
