C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Short blasts don't prove much except maybe which driver has the better reaction time. Try running for 20 minutes with some curves thrown in and lots of wide open throttle time in the middle triple digit range.
Bill
And just because you may have deeper pockets than the other guy, it doesn't mean he won't wipe the floor with you on lap times.
Is what I meant to say. If you see me on the Beltway, or coming out of turn 8 side by side to the straight away. You WILL get rolled up. Both of those Stangs had blowers. That was my lil motor. If you look scary enough I turn on the bottle. The guy with yThundercats logo. Come get some
Trust me. You want none of that. But if it happens, message me.
Side note, don't be offended if I don't hit it if you were to ever "roll up on me". I take it to the track. Done with the street scene. But best of luck to you on the Houston streets. Sounds like you may not be too familiar with what's actually running around out there.
