[Z06] To those who think the C7Z is a slouch
#41
I don't think it's a slouch at at all. It's incredibly fast, however even if it had 10,000 horse power you still can't fix fugly! C6 Z06=best looking corvette ever made period.
#42
Capisco and you are just trolling unless you have some proof. Your just hating and are clueless about drag racing and the effects of good track prep and DA.
Get a clue and stop the hate. Offer some proof or your just making yourself look stupid.
#43
I used to feel this way too when the C7 was first released. But when I saw the C7 Z06 though it grew on me. I don't see how some call it ugly. Its pretty much a copy of the Berlinetta. Which is a sexy *** car. The back could have been better though.
#45
He ran at MIR so I am not impressed at all with that time and mph. They are seeing negative DA's on a regular basis up to -1600ft. That car will not run that time or mph anywhere here in CA. At Fontana it will be lucky to see 122mph given the typical DA even now is north of 2000ft and in the summer it is above 5000ft. There are tracks up north that have better air and elevation but not as good as MIR. WE simply do not see conditions like they do.
If someone out here runs those times and mph then I wills ay it is doing well but it wont. MIR is the same track Ranger set those crazy fast times in his stock C6 Z with -1500ft DA's. Out here typical stock Z's struggle to break 122 unless the weather is really good. Carlsbad raceway was the only local one that had the potential for great times and it closed a long time ago. I live in an area that is 1300-1700ft above sea level and I notice a massive difference in my car going down to west side near Santa Monica and I have never seen negative DA's there either.
So basically to those of you who are impressed with this you need understand what is going on here before you snap to judgment.
#46
#48
Thank you on the first count.
As to the 2nd. I hear you. Its an auto. Its not about driver skill its about what the car can do in this case. If you put the A8 in the Z06 I wonder how it would do. Do you think at the power output of the LS7 it will beat that time? The manual on drags is a big advantage. Once you put drags on the C7 the Auto will be a disadvantage.
Ill put it this way. Are you impressed with the bugatti veyron?
Same reason I've never been impressed with the GTR. They are for people who don't really care about driving just going fast.
#51
There's more driver skill in running a strong powered auto than you give any credit. It's not just stab the gas and hang on. When traction is limited to anything less than a WOT dead hook, you still have to play the brake pedal vs the gas on the launch. The down track auto shifting is simpler, but any driver worth his salt can shift a manual quickly. It's not like I've never driven manuals, since 30 were, of the 61 cars I've owned. 5 of the 10 that saw dragstrip time were manuals too, and I can't count all the manual shift drag cars I've driven that I didn't own.
The real difference is that on a prepped track with DR's, an auto car is consistent, while the manual car depends on the driver to be consistent. So yes, a hero run where all the stars align, a manual shift will be quicker than a stock auto. Put in a high stall to allow an equal launch rpm and the auto eats the manual 9 out of 10.
#52
Also, do you think our government is behind 911?
#53
I used to think drag racing with an auto was child's play, till my buddy let take his 2300# tubed 70' nova down the road. I built his engine; 900hp aluminum BB running alcohol through a flying toilet. Two speed. Scared the shiittttt out of me, and I am not too proud to admit that. And all I had to do was floor the peddle, release trans brake, and make one shift. Just keep the f'er in a straight line. Yah, right..... easy my ***......
I still don't like the C7. I don't like boosted engines, and I don't like the weight. I'd rather have a Viper.
#54
Received 2,061 Likes
I would think with the modern auto transmissions offered these days they will always be quicker than a manual, definitely will shift faster. The A8 has launch control so it should allow you to launch higher. Not sure, either way automatics are like fake bewbs, they can be fun but will never replace the real thing.
It all comes down to the launch. All launch control does, is to restrict the power just enough to avoid spinning. i.e. TM on steroids
With a stock 1800 RPM converter, the launch RPM is limited to 1800. Pretty simple to understand, right? Yet the manual has the capability to launch at 1 RPM short of the rev limiter. It takes a very talented driver to learn how high he can launch and control the clutch for the best 60' time. It sure won't be the average Joe who can do that, but whoever can, will beat the best stock auto's time.
A higher stall converter changes everything and the odds swing in the auto's favor.
#55
You obvious missed the point. Yes, the auto will shift quicker, but the manual won't have the slippage driveline losses, so that part is a wash.
You can break stall an auto higher than the stall too. You wont get anywhere near what you can with a manual but you can cheat the stock stall too. Less chance of breaking things too.
I do it with my Auto C63 and I can get a launch at about 3500-3800RPM for a 1.7 60' tune only. Not bad for a heavy sedan.
Put some drags on the C7Z and break staling will get that 60' down. Maybe even 1.59 territory based on this guys run. Once moving a manual will not beat the auto unless your power shifting and VERY talented.
