[Z06] Removable front license plate bracket-Recommendations
Bought a 2013 Z06 with a carbon front splitter. Because I live in a two plate state, I know that sooner or later I will need to install a front license plate bracket. I drive the car primarily to car shows so I am looking for a bracket that is easily removable. The front splitter precludes me from using a "pop up" type bracket.
Thanks for your help.
skjz16
skjz16
Received 8,926 Likes
skjz16
skjz16
http://www.topflightrepro.com/corvet...brackets.shtml
Bill
These work very well and if you purchase the optional license frame to match your car's color they will look like factory mounts.
Bill
Bill
Bill
Bill
Clif
I went with the plate bracket from H&K vette accesories. I like the placement and the form a lot better than the top flight model. This doesn't require sticky tape, or visible modifications when you take the plate off. I did not even use the additional plastic pop clips and it held securely at a "decent" speed.
I can remove it with 1 1/4" socket wrench of nut driver that is easily kept in the car.
https://www.corvetteforum.com/forums...e-bracket.html
Liceense bracket
Bill
Bill
skjz16
License Bracket
License bracket
skjz16
