[Z06] No Power Steering Cooler with ECS Kit??
I posted this in Forced Induction too...but thought I'd post here as well....
I just found out you lose your power steering cooler when installing an ECS S/C kit on a LS7.
What are my options? What is the majority of ECS LS7's doing?
What is the negative of not having a PS Cooler? This car will not be hot lapped or circle tracked/autox. It may be driven 3-4 hours at a time on road trips, and used for some roll racing.
I'm not familiar with the ECS system. Having said that, I would replace the radiator with a Ron davis Z06 radiator, use 2005 Z51 oil cooler lines, and use the oem Z06 oil cooler as a power steering cooler plumbed with AN fittings and hoses.
No power steering cooler is fine for a drag race only car. C5's & C6's have enough problems with leaking racks and pumps due to high fluid temps. I would not have some sort of cooler on one of these, especially since the OP stated that his reservoir is overflowing.
How much fluid did you put in the reservoir?
I am confused as to why mine is burping a bit of fluid. looks like it is getting hot!
jb
jb
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,085 Likes
That's strange. We are making an option right now for a cooler though. I actually have it sitting on my desk as I type this. We just need to make brackets for it.
I'll PM you when it's completed, but I have never seen a system "burp" if it's not a road racer. Actually even then they didn't burp, it just ate up racks over time too quickly.
Sounds like a bad lid.
maybe burping wasnt the best word to use.
After I turned my car off yesterday (drove for about 30 minutes)....you could see a bit of fluid residue on the reservoir, and hood. Also, the cap/lid was sputtering a bit from the vent in the cap/lid (hot fluid steaming inside as it looked)
I am in Florida, and it has been hot.
Any recommendations?
Received 8,928 Likes
You might want to talk to Doug about his cooler.
Bill
it was shvitzing on the underside of the hood...and just a little spray....not alot.
I removed some fluid (may have been slightly overfilled)....and we shall monitor!
thanks to all!
thanks to all!
