[Z06] Car burning oil a problem?
Oil life on my DIC tells me I have about 50% left. Just checked my oil and I'm at least a quart low. Is this normal for the ls7?
This is an '08 btw if it matters
I'll bet that usage is within factory specs, not that I put any faith in that. As low as their minimum warm idle oil pressure spec is, your engine could be about to grenade and they'd say all was good. I think i'm around 36K miles and mine has never used oil between changes.
Assuming no leaks?
Most likely your valve guides are worn and the valve seals can't do their job because the valve is moving around too much. LS7 are not known for having piston ring sealing issues, so the only other place the oil can go is through the valve seal.
No leaks that I know of. I always check when I leave a parking spot to make sure. Let me guess, this means I'm about to drop a valve? lol
I laugh cause I don't want to cry
Are you getting any blue smoke on first start-up? If so, that is a sure sign the valve oil seals are leaking and you probably have bad guides also.
Haven't paid attention but I will now. I know it smoked a little when it was cooler but I thought the outside temp might have had something to do with it
Ok. Didn't see any when I left work but I was just looking out my mirrors. Might get a buddy to start my car and see if it can see any blue smoke. Thanks for the info
Wil Cooksey #256
Mine burned 5 quarts on a 10,000 mile trip. I found out my guides were out of spec. New heads and valve guides and now it burns about 1/2 quart in about 7,000 miles. I kept relling the dealer about the oil consumption and was told it was within range.
Good luck
Good luck
Wow...
Received 8,927 Likes
Have you been doing any high rpm wide open driving (not quarter mile stuff or stop light to stop light blasts). Long periods of high rpm wide open throttle operation will bring some oil consumption. LS engines can use a quart per day at a track event and that amount isn't considered unusual.
Bill
Bill
Bill
Bill
