[Z06] lifter bore damage.
lifter bore damage.
installing redone heads and figured I would check the lifter wheels and cam lobes while I was in there. one of the lifters on cyl # 7 was sticky coming out. once out I found some very small horizontal scatches/abrasions on the lower side of the lifter bore near the top of the bore which can be felt with the tip of my finger.
Suggestions???? there are no marks on the lifter body.
thinking maybe just a little 400 or emery cloth and dress it out enough to get the lifter moving smoothly.
any help would be greatly appreciated
rob
rob
Lifter body to bore clearance is critical. If it is excessive, oil pressure on the lifter will not be adequate to keep the lifter pumped up. You can hone a bore, but not unless you know clearance. Normally, if you have lifter bore damage, the bore will require bushing, or sometimes, you can bore it out and run a Ford lifter. GM clearance spec is not much. .0013 - .0018.
Thanks again Michael. You are certainly an asset to this forum. I am planning to borrow a bore guage from the machine shop tomorrow and will report the results.
Had this happen on one block of mine. Lifter was rough coming out through top.
When machine shop looked at it, they said it needed repair via a bronze sleeve honed to size..
Hope yours isn't as bad.
update. checked with the machine shop and they did not have a bore guage that small. best I could do was use a telescoping T guage and measure that way. as it was just a couple of marks in the portion of the bore above the oil gallery I used a small piece of 400 on the end of a round dowl to dress them out. result was approx .001 increase(as best as I could measure) in the bore dia only in the small area I smoothed out. The engine is back together and running, and quietly. havent driven the car yet do to weather but with the oil temp up to 160* oil press was 33psi at idle and jumped quickly with any increase in rpm.
thanks for the replies and interest.
Rob
Rob
You'll be fine. Usually the rule of thumb is .001 to .0015" for every 1" of bore clearance for just about every bearing and bore in the motor but loose isn't a big deal. The saying goes "clearances too tight and everyone knows but clearances too loose and only you know"
........why do I even bother.
No I did not. These lifters only have 5 k miles on them . I did find a slight burr on this lifter body which I am sure caused the issue. Cleaned it up and put it back in. Should have checked them closer before installing them the first time. Don,t assume just because they are new.
Rob
Rob
rob
rob
maybe but it was the first thing popped up under google search for how to remove stuck lifter. My prob atm 2 roller lifters bottom mushroomed out after went to valvoline quick lube and they didnt prefill oil filter. Soon as started car it collapsed 2 lifters. 2 pushrods fell off rockers an lifters started banging against cam. One came out easy the other i broke k&d lifter extracter trying to pull it out. Not even wedging wrench under visegrips worked. And pulling engine out of car to remove cam not an option. But i have an idea to try in the morning. Anchor bolt from home depot wedged in lifter barrel an connected to a 5lb slide hammer should either get it out more make a big mess. I dont have 2 days to wait for similar tool to be delivered.
First of all, never remove a damaged lifter from the top. Remove the cam and push it out.
And not prefilling an oil filter causing lifter damage? That is a new one. I've never prefilled an oil filter in my life.
well got mine fixxed found a 5/8 x 8inch sleeve anchor from home depot was just right to wedge in lifter an my 5lb slide hammer screwed right in to a coupler between the 2. Took 3 good hits to get it out an scratched up the bore pretty deep. If i remember ill take pic of how bad they were. An yes if u dont prefil oil filter on hydralic lifter engine u send a burst of air thru system an often damage something. Anyways cleaned up some 4.3 v6 lifters an pushrods got it all done runs great an oil pressure 80lbs cold 60lbs hot. It was 30lbs cold 10 lbs hot before fixxed. Now im back where was before wejt to that idiot oil change place. So happy went an did donuts on the rev limiter 😁
