C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Light-em up. LED Conversion kits from Radioflyer Innovations
Old 05-04-2015, 11:42 AM
TheRadioFlyer
Supporting Vendor
TheRadioFlyer's Avatar
Default Light-em up. LED Conversion kits from Radioflyer Innovations
At Radioflyer Innovations, we believe corvettes are meant to get attention. What better way to do that than having a modern lighting system to turn heads day or night. Our Cree-LED complete lighting kit is the brightest and best-looking way to draw attention to your car every time you drive it.
Our LED bulbs use Cree XP-E LED bulbs for brilliant, long-lasting light that sets your car apart from even other corvettes. Our LED bulbs are substantially brighter than their factory counterparts and with the ability to use factory housing or aftermarket housings gives you the flexibility to retain the purist look when parked or that all-out custom look.
Unlike other kits, we color-match the LED to the lens it will be paired with. Red LEDs go behind red lenses, Amber behind amber and white behind clear. This gives the purest color and a look you can only expect from Radioflyer Innovations products.
The kit comes complete with every bulb you need for the exterior and every major bulb on the interior of your car.
The C6 kit comes with several options for hyperflash, as simple as our splice-in resistors (pictured below) or as exotic as our all-new White-DRL harness which when paired with a switchback bulb makes the DRL white while still retaining the amber turn signal.
Click here to Purchase the C6 Kit
The C5 kit comes with our Hyperflash Harness to retain factory turn signal flash rate. This harness simply plugs in under the driver's side dash and eliminates the need for load resistors
Click here to Purchase the C5 kit
Best of all, these kits are on sale at 10% off for the rest of the month (while supplies last) Just use the coupon code "News501" at checkout to get your discount.
Old 05-06-2015, 08:02 AM
TheRadioFlyer
Supporting Vendor
bump
Quick Reply: [Z06] Light-em up. LED Conversion kits from Radioflyer Innovations
