[Z06] Z07 Sticky
#681
#687
Yes, my Vette did come with a Carbon Fiber hood. It had the Carbon package. I tried to blacken out all my lights, but a CA Highway patrolman pulled me over and gave me an equipment ticket.... Had to remove the covers. Too bad, the car really looked bad *** with all the side and tail lighting blacked out !
#688
Are smoked lights in ca illegal as well?
#690
So I have a 2013 Z07. I'd like to get rid of the 2 extra cats on the oem x pipe, whether by going aftermarket or finding an oem zr1 x pipe. "Must" I get an x pipe made for the 2013 or can I use an x pipe made for earlier years? I feel like whatever year x pipe you get, it will be the same "overall" length except the oem 2013, which is made to accommodate the extra cats.
As an alternative, what would happen if I go to any muffler shop and get rid of the x all together and just fab up 2 pipes that go straight to the mufflers?
#691
$425.45
http://marylandspeed.com/corsa-bolto...31-p-6160.html
$451.97
http://www.summitracing.com/parts/cse-14331
$446.64
http://autoplicity.com/5223350-corsa...vCsaAtl38P8HAQ
Thanks,Matt
#692
2012-2013 C6 Z06/ZR1 CORSA X-Pipe
$425.45
$451.97
$446.64
Thanks,Matt
$425.45
$451.97
$446.64
Thanks,Matt
#694
That's why I gave you the links to the only one who make the cat less x-pipe for your year that will be a direct bolt on.
Thanks, Matt
#695
I'm bringing in this photo. I hate to beat a dead horse but the dimensions of the earlier x-pipes look the same as the 2012+. Only difference are the addition of the cats and the positioning of the "X." So why wouldn't earlier x pipes fit? Thank you for helping me out!
#696
It also does NOT have the same flanges on the X-Pipe where they attach to each other (see your picture, they are reversed)
You cannot use an earlier model X-Pipe on the later model year (2012-13), you will have to either gut your X-Pipe's cats or buy the Corsa aftermarket X-Pipe or buy the earlier model downpipes and earlier model x-pipe and install those -
Thanks,Matt
iwantaz06now (02-09-2017)
#698
Pro Mechanic
Pro Mechanic
I have done the 2011 retrofit.
GM changed the connections at the front of the mid-section for MY12, so, if you want to backdate your 2013 exhaust to the 2011 2-cat system, you need both the front cat assemblies (wvhich have the proper connections) and the 2011 mid-section which is the only one with an X-pipe and no cats.
It was worth 11-hp at the wheels SAE corrected.
I wrote about the 2011 exhaust retrofit in my C6 blog on another web site. the CF's rules prohibit me from posting a link or mentioning the site's name, but if you search for <Blue Bullet Blog post #224> you'll likely find the article.
A less expensive alternative is the CORSA X-pipe.
#699
#700
I'm selling my 2013 Z07
If anyone knows anyone who wants a cream puff please share!
https://www.corvetteforum.com/forums...clear-bra.html
