[Z06] Think my clutch may be slipping. Do you agree?
I thought it was blatantly obvious when a clutch is slipping on the dyno, by seeing basically a mountain range on the dyno sheet.
This time I don't think its that obvious, but I think it's still happening. A good engineer I've been working with told me to look at the data closer
Take a look at my dyno sheet
The weird thing is that typically after a few pulls the car gets hotter and the power drops. In my case the car is getting more powerful with each pull
These pulls are back to back within seconds of each other
First off the torque is very low for a 550hp car.
So after the first pull I gained 5hp and 19TQ
then after the second pull I gained 7hp and 26TQ
you would think someone was tuning the car! This leads me to believe the clutch isn't holding the power as it should, perhaps with the heat its holding better
2nd example
look at the speed vs hp graph below
If I plug in the data here http://www.wallaceracing.com/calcmph.php
put in my tire height of 27.15, stock z06 gear ratio and rpm
I start off even and end even but at 5,250 I'm off by 12mph to the slipping side. So the dyno says I should going 112mph when I should be going 124+. At 4,000rpm it is about the same.
Are we wrong? Crazy? Opinions?
2nd example
Wil Cooksey #256
I would think if your clutch was slipping, when in 4th gear at WOT you would expect to see the RPM's rise rapidly compared to wheel speed. These graphs look similar to mine. With 3 pulls, back to back, I see hp and tq increases also, this is normal.
Thanks guys.
Is the clutch slip always that obvious though? Just wondering if im making any valid points or way off base.
Also the low torque numbers are whats getting me.
This is a HCI Z06
This is a HCI Z06
I don't see anything that looks like clutch slippage there. Not surprising that it gained power with each pull. As the engine oil, trans fluid, and diff fluid heat up, there is less parasitic loss. The only reason the motor would make less power after a few pulls, is if the coolant temp or IAT is too high.
When I've seen organic clutches slip on the dyno, there is usually clutch dust coming out from behind the car, that looks like it is from the exhaust. Not sure what clutch you have.
