[Z06] Qustions for Darrin Morgan.......
Ask him about potential reduced guide wear on LS7's utilizing a roller-tipped rocker vs. the stock rockers (just any roller-tipped rocker - the builder will worry about MOI / spring rates / weight over the nose, etc.).
Or, put another way, what role do the stock rockers play with their questionable bearing tolerances (slop / side to side movement) coupled with the scrub radius (even with the stock cam), and considering the production machining tolerances of pedestal height / centerline, etc., and using the current Mobil 1 factory fill (reduced Zinc, targeted for gas mileage and emissions, not wear reduction)?
Thanks!
Thanks!
Ok guys anymore questions I need by tonight please I will try to address all the questions and I will post in another thread the questions and answers...Monday or Tuesday
Im sorry I didn't t know I was obligated to respond at your needs,if you want Chief well here you go he nailed it. Then if you want to talk to Darin Call him then. Thanks
#35
As for everyone else waiting patiently I will gather the data and post them as soon as I can sorry for the delay. I want to gather the data and put each question with answers in order and make it understandable for everyone.
#36
I will give you at least one answer to everyone's question..
1.Oiling without the guide getting enough oiling and lubrication premature guide wear will start.
2. Rockers everyone is curious on rockers and swipe pattern yes. Well stock rockers are fine he said with the trunion upgrade, Second measure and check if you are using the same rockers when car was stock to add to heads. If there is any wear or how can I put it non smooth surface then yes rocker geometry does equate to guide wear. Those 2 key important things are what he specifically told me.
3. Changing ss valves is a plus he says manly is perfect, ferrea is over kill for a street car he says only if your dragging the car or road course racing the vehicle.. Oils to use I will post the oils he told me ... Thanks thats all the time I have today.
#39
