[Z06] Sticky tires for 2006 w/ stock wheels?
Hi guys, I finally purchasd a 2006 Z06 after many years of anticipation. I'll be sending the car to Ragin Racin almost immediately for their stage 4 heads/cam package. I'm looking for recommendations for a sticky rear tire for these power levels that will fit on the stock 2006 wheel. I'd prefer a drag radial but I'm having trouble finding one that I know will fit. To all the modded 06 owners running the stock rear wheels, what are you running?
Thanks for the input.
Mickey Thompson 305x35x19 DR works well on the street and can double for some drag strip use. The rim does protrude a little due to its narrower profile. All in all it is a good compromise tire.
Im running a Nitto NT05R 345/30R19 on mine. a little under 600 HP
Invest in some rims before just tossing better tires on the OEM setup. When that junk breaks at speed, good luck to you and those around you too.
thats the front rim
Wow, thanks for the input. That doesn't look like a fun experience. Looks like I'll be investing in some new wheels. Anyone have any recommendations for lightweight ones?
And your point is? So dumping the clutch with stickies is going to be easier on the wheels?
Before any recommendations, my question to you is how much can you afford to spend?
One can get into a set of OZ for about a couple grand. It goes upwards from there to 7k or better...
Would "stickier" street tires (not drag radials) be okay with the stock wheels? Surely there are plenty of heads/cam z's running stock wheels? Thanks again for all of the input guys!
I think the answer is, yes, Dumping the clutch with stickies will exert far less force on the wheel than the force that can be exerted under heavy braking. In most cases, of course it depends on the variables, but most vehicles can create 2x or more g-forces under braking than under acceleration. Straight line acceleration g-force is of course insignificant when compared to lateral and braking forces placed on a wheel. And that's not even counting if you have the dreaded wheel spacers on!
As for the MT 305 DR, we have been low 1.6s on a relatively soft launch. As for launching these cars, in general, it's not a good idea to dump the clutch. Something needs to slip/spin. Slipping the clutch will minimize (not prevent) breakage. Running a bias ply tire will minimize (not prevent) breakage since they are more forgiving than DRs. Bias ply tires also recover while spinning which also minimizes (not prevents) breakage. Bias ply tires will generally 60' better and are much more consistent. However, it's imperative that a set of skinnies be used with a bias ply tire.
Can you elaborate as to what exactly happened? I've never heard anything bad about OEM Speedline wheels and guys have been running OEM Speedlines on C5 and C6 Z06s since 2001 on the street and the track. Never heard of any of those wheels breaking so this is new news to me. Your input is appreciated.
I know it has factory marks on the inside of the wheel but is this wheel from The House of Wheels?
Without going to racing radials you're not going to get a sticky tire.
I've had NTO5's and now Bridgestone RE11's.....spinning them is easy.
I wouldn't be real concerned with the stock wheels.
I have a pair of NT05R's 245/30/19 mounted on stock rims. I wish I could run them on the street, but I'm a little old to be replacing tires every few months.
What happened is the wheel failed from the inside out and that my pre-event inspection didn't show anything out of the ordinary. The failure happened at about 70 mph, tracking out from a turn at the end of the front straight. It felt as you'd assume...big bang, lots of smoke/dust and a loss of braking and control. I was fortunate that the runoff area was deep and didn't have a wall to hit as I traveled about 75 feet off the track surface. The remainder of the wheel/tire wasn't found until a day later as it had traveled hundreds of yards into the desert.
The tires were Bridgestone RE-11s, a normal high performance street tire.
