[Z06] Radiator fan is stuck on?
I start the engine and the radiator fan comes on and stays on - will not shut off; something wrong I think since its never done this. No A/C, interior fan, nor defroster is on. What's wrong?
I recently pulled a headlight to replace it; car was up on stands for a couple weeks with a trickle charger. I'm not sure if that's related or not. Suggestions?
AdvTHANKSance
AdvTHANKSance
AdvTHANKSance
AdvTHANKSance
thanks. I temporarily disconnected the drivers side headlight and the sidemarker. I tested the new headlight before putting everything back together. I'll try disconnecting the battery but I doubt I'll be that lucky. Where would the temperature sensor be?
Without looking at the wiring I'm not 100% sure. But there may be one in the side of the rad on passenger side. If you did passenger HL, possible it got bumped? Could find the relay and swap,with same kind to see if that does anything.
Well I disconnected the battery for a bit and pushed the fuses and relays down in the fuse box and the problem seems to have gone away. Some of the fuses felt loose, I'll post back if the problem comes back. I sure thought that after self inflicting $700 of damage to that headlight that would be the end of it, but maybe there is more in store...
