C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Starter - second one melted.. any aftermarket options?
Old 06-09-2015, 10:02 AM
silvrhand
silvrhand's Avatar
Default Starter - second one melted.. any aftermarket options?
So I've now overheated the solenoid on my second starter.
ARH headers with jet coating still too much heat for the starter, so I'm kind of at a loss of what to do next. I wrapped this one but apparently not enough, so now looking at other options.
- aftermarket mini starter that has a bit more shielding.
- some heat shield for the starter that actually works?
- just friggin jet coat the starter to reflect heat better.
Has anyone slayed the heat demon for starters yet? I hate being left stranded by a solenoid cracking due to heat, and my wife will never let me hear the end of it if she gets stranded by one.
Old 06-09-2015, 06:36 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
Can you post a pic of the starter where you had the issue?
What sort of wrap / shielding are you using (brand, pic if possible)?
I've been looking at a few solutions (I haven't had an issue yet, but trying to be proactive) - one of them is basically a semi-flexible heat shield that utilizes stainless steel ties to attach to the header (would be similar to the factory exhaust set-up).
Old 06-09-2015, 06:52 PM
silvrhand
silvrhand's Avatar
www.ezshields.com has a template you can use to mold around the starter, I wonder if I get that and put the heat shield wrap on it if it'll start off enough heat.
I used a heat shield wrap like the DEI one from amazon last time, and it obviously didn't work, the solenoid still cracked and the bolt from the battery is now loose in the housing again.
Old 06-09-2015, 07:28 PM
Dan_the_C5_Man
I like it - and this is the stuff I was referring to (I think)..
http://www.heatshieldproducts.com/au...ield-armor-kit
Or maybe this one - http://www.heatshieldproducts.com/au...n/header-armor
Maybe do both (starter shield and the stuff I posted)!
Their pre-cut underside intake manifold shielding is interesting as well.
Old 06-09-2015, 08:10 PM
jburt
jburt's Avatar
http://www.msdignition.com/Products/...7_Engines.aspx
My friend and I both had this issue. We both now have this, problem solved!
Old 06-09-2015, 08:15 PM
CyberZ
CyberZ's Avatar
I had my kooks ceramic coated and I can touch the header immediately after driving the car without getting burned. I have not been near the starter but the underhood temp is much better.
Do your headers get super hot and not able to touch?
Old 06-09-2015, 09:26 PM
erick_e
Support Corvetteforum!
erick_e's Avatar
St. Jude Donor '13-'14-'15-'16
Although I don't have a shield I've heard good things about the Thermo-Tec 14150 Starter Heat Shield and have considered one for myself.
Old 06-10-2015, 09:06 AM
silvrhand
silvrhand's Avatar
How did you actually connect these up the OEM starter has a plug to the starter, I really didn't want to have to cut into that to get it to work.
Old 06-10-2015, 09:17 AM
erick_e
erick_e's Avatar
I'm sure you could find a pigtail to mate and connect to that starter so you didn't have to cut into your factory harness.
http://www.acdelcotechconnect.com/pa...tails-catalog/
Old 06-10-2015, 12:15 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
40k miles, 22k of those with headers. Still OEM starter, never an issue. Running 2" ARH on a 1000+hp car and starts fine in 110F weather. I think something else is funny on these cars that keep killing starters.
Old 06-11-2015, 09:22 AM
Michael_D
Michael_D's Avatar
Me to. Probably ground related.....
Old 06-11-2015, 11:45 AM
KLLRVET
KLLRVET's Avatar
I believe you are on to something Michael_D. In the near future I plan on adding an extra ground or two hoping to help hot starts.
Old 06-11-2015, 03:11 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
Me too as I've raced on some crazy hot days here and the only time I ever had issues was when either my battery wasn't fully charged or I had an ever so slightly loose connection on the power lead going to the starter solenoid.
Old 06-12-2015, 12:23 PM
silvrhand
silvrhand's Avatar
It's disentigrating the solenoid nothing else.. physically the rest of the start is fine, but the postive post on the solenoid side just breaks free. I'll take some pictures when I pull it out tomorrow.
I have one sneaky suspicision is that when my AC is on and consdensation under the hood happens I suspect maybe water is hitting the solenoid and cracking it, you can definitely hear it hitting something and sizzling. I always assumed it was the headers.
Old 06-12-2015, 12:38 PM
x88
x88's Avatar
Hmm I hear sizzling after parking as well... maybe thats what I'm hearing!
Old 06-12-2015, 01:02 PM
v8sten
v8sten's Avatar
Im with these guys. i have 2" kooks headers on mine and it regularly sees track duty (lots of starting in the staging lanes) and is a daily driver in this houston heat. if you have a grounding issue that will cause the amperage to skyrocket and amps cause heat, heat fries starters. putting insulation on it is only holding the heat in. in theory making the problem worse.
To Starter - second one melted.. any aftermarket options?
Quick Reply: [Z06] Starter - second one melted.. any aftermarket options?
