[Z06] Help me pick ID850s
Help me pick ID850s
Have a FAST intake and RSI fuel rails, need the 850 sized injectors for an E85 build.
The ID website shows ID850 replacement LS7 is part number 850.34.14.15.8
I think that translates to :
850 flow rate
34mm length
14 mm fuel rail bore
15 - not sure what this is for?
8 cylinders
Now I'm pretty sure I need 60mm injectors so that spacers aren't required. ID lists some "Universal" sizes, one of which is 850.60.14
Will that work for my setup?
850 flow rate
34mm length
8 cylinders
15 means 15mm lower o-rings. Probably going to need the short spacers they offer. Have you contacted them? They are pretty quick at responding to emails.
Good point, should have tried that first. Here's their response to me asking if 850.60.14 is the correct part number:
That would be correct. The standard bottom O-ring with that fitment will be 14mm but that intake manifold could possibly use the 15mm lower O-ring (like a factory LS7 injector) so you would just need to specify to include those on the side as well. just in case you need them.
Contact your ID dealer of choice and they can set you up.
I've got IDs from FSP and DSX. Both have good price and service.
