[Z06] question about Factory muffler removal
i currently have 2012 ZR1 mufflers on my 06 Z06, and wondering how high does the rear of the car needs to be raised in order to remove the mufflers ( installing other mufflers )
my nose hits the ground from jacking the car up so high and i still cant get them out. i have to use a lift
Not sure how much difference there is between the Z06 and ZR1 mufflers, but if they are about the same size then the passenger side is a bear to remove. I had to drop the rear sway bar and remove the splash pan and then with some patience and maneuvering I finally got it out (be careful you don't damage some wire connectors that are near the passenger side muffler). The driver's side comes out pretty easily.
Thats how we did it. Once on a lift and once without. Lift def helps but you can do without one, despite what others say. You'll need a second set of hands FOR SURE though
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
Received 1,334 Likes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
I got my factory mufflers out this way today. i also have the ECS trans brace and it made it a pita to get the pass side muff out. i had to drop the cradle to get it out.
-jp
i did it by myself, so there wasnt any extra hands to pry with, it had to come down so i had to undo the shocks to get it to freely separate. i will also state i have the ECS trans/diff brace to contend with. it was tough but it came out and went back in too.
