[Z06] ****NEW Hinson Header Install, Sound, and Burnout Video****
Former Vendor
Hinson Motrosports is proud to bring the C6 and C6 Z06 Corvette market the first set of MADE IN AMERICA, stainless steel, ceramic coated 1 7/8 headers for under $830.00 shipped to the lower 48 states. The headers are all mandrel bent with 1 7/8" primary tubes, 3/8" thick flanges, and 3" collectors. Also, all of our headers and x-pipes are ceramic coated to help reduce heat under the hood and the interior of the car. Our headers slide in to place without the need to loosen the engine mounts or the front crossmember. Installation time is short and can be done easily from below the car. Fitments currently available for the C6 wet and dry sump models with off road connections only.
*Expect to see gains of 25rwhp or more from the addition of these headers with a tune.
Click Here For Prices & Purchasing
*These cars are also equipt with the NEW Hinson Motorsports short throw shifter. Email chris@hinsonmotorsports.com to be put on the contact list for availability of this great new item.
Price Includes
- Ceramic Coated Stainless Steel Headers
- Ceramic Coated X-pipe (Select your vehicle)
- Aluminized steel rear axle back connection pipes
- O2 Sensor Wire Extensions (x2) $50 value
- Clamps
Vette in video has a cam?
Former Vendor
Order placed!
Thank you!
Thank you!
This is an excellent price! I wasn't planned on ordering headers for a while but I may have a change of heart if this price is locked in for a while...
Economically speaking, the $1500-2000 for 10-20hp just didn't make sense to me, especially when a solid 20-30whp could be had from a tune alone.
Former Vendor
Thank you for the purchase and the opportunity to work with you.
Yea $2000 is a hard pill to swallow for sure. This is the price we plan to keep, so pick you up a set and put the remaining funds toward something else that adds hp.
Former Vendor
For those of you curious about user reviews check this link out to a recent customers response.
https://www.corvetteforum.com/forums...rsports-2.html
Out of curiosity, would you be willing to custom fab a set of Tri-Y headers instead of the standard long tubes?
I'm more interested in power under the curve on an otherwise stock top-end, which Tri-Y's seem to do better with...
Former Vendor
I'm sorry but we are not interested or plan to do any custom header setups. The material and labor expense of a one off set would be astronomical.
