[Z06] Big cam guys.... who went to 4.10 gears?
I have an 09' Z06 with the LPE 660 kit with the GT21 cam. Cam surge is getting on my nerves and makes driving my car on the street less enjoyable. I drive around in 3rd to keep the revs above 2,500.
I was wanting to know if I put in 3.90 or 4.10 rear gear if it would help with the surging by keeping the revs higher and allow me to use 4th and 5th gear more? Also I would think that the shorter rear gear would make starting in 1st gear much easier right?
I've been reading up on this and would really like to hear from guys that have larger cams and possibly had the same issue(s) I have.
If you did swap form OE to 3.90 or 4.10 who did you buy the parts from?
Put a milder grind in it, you'll be happier and like the car again.
Get someone else to look at the tune. I've seen a couple files of LPE/ 660 tune cals, and they were shiit. No idea if they were canned calibrations or just a hack tuner, but they were woefully lacking talent. I would start there, prior to gears or cam swaps.
I thought about getting a new cam but don't want lose the HP. I guess I'll have to see what a few of the tuners say.
Already did. Some of the issues I had have been fixed via the updated tune. Now it's just the low RPM surging that I have to deal with. Local tuner says it's a BIG cam and there will be surging below 2k RPM.
This is why you don't put a big cam in a daily driver. Sure it sounds sick and the gains are amazing but the surge gets old fast when you drive it in traffic or on a daily basis.
Change out the cam or find another car to drive daily.
Changing the gears isn't going to help. That cam shouldn't have surge above 2000 RPM under load w/ a good tune, but I will say this about the GT21...the lobes are WAY too aggressive for the LS7, IMO. Personally, I'd change it out to something with softer lobes and less overlap...kill 2 birds with one stone. I've seen too many valve train issues with the more aggressive lobes on this motor.
BTW - I bought this car as is. I didn't have it built this way.
My tune was done by a shop here locally and I do not have the file. As I said above the car runs much better now that it's been tuned. I just think I am asking the car to do more than it's capable of doing with that cam.
The car runs perfect when not in city traffic and the revs are up.
Wonder why the previous owner sold it? Took the fun out of it maybe ? Go down on the cam, you'll be glad you did, forget the high rpm bragging rights on the hp.
Yup. I still wouldn't use LSKs on a 1.7 rocker either. I feel like an old fart saying to tame things down a bit, but over the years, I've found that the ragged edge stuff just gets old quick. These days, I'm more about reliability and drivability. Getting to the office in your dress clothes, smelling like raw fuel, just ain't as fun as it used to be
RPM Trans. sells complete 3.73/3.90/and 4.10 C6Z (built) diff's. Stage 3 and 4. Pricey but......
