[Z06] ls7 evacuated a piston
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,092 Likes
The head of the valve pops and leaves the stem/spring in place, as viewed with the valve covers off. Your symptoms are text book for a dropped valve, FWIW.
Received 1,679 Likes
That SUX Bro....Couldn't have happened to a better guy... Look at the bright side though Ryan. Now you can build a new engine and "maybe" keep up with me.
Originally Posted by LFZ
Just because you have a solid valve...doesn't mean it won't snap.
*FYI..I have dropped a SS valve in my other vette (non LS7 so calm down )
I'm comfortable with the solid stem stainless steel exhaust valves I have in my C6 Z06. In fact, at all RPM's up 6,800 RPM, I have less valve bounce than the stock OEM exhaust valve, according to Katech's spintron testing(stock cam with dual valve springs).
Since I don't like accidently hitting the rev limiter, I shift at 6,800 RPM instead of the factory redline of 7,000 RPM, so I haven't lost anything but 200 RPM.
Received 8,919 Likes
Bill
I redline the **** out of mine , track it regularly and change at 7200 no issues never hit the limiter though or Mis shift if i loose a valve I'll just upgrade to a full mast block , gives me a reason to buy it that way - or at least justify it to the wife!!
#33
Yeah. I'm pretty sure this block is going to be a coffee table in its next life.... as much metal ended up in the intake and seeing it in a few intake ports I think it's probably a goner. Seeing all the coolant in the intake and the fact the passenger side motor mount is saturated (but no smoke show during the incident) makes me think the block is cracked.
#34
I've never dropped a valve(thus I haven't ever broken off the head) in any car I've had and that goes back to 1959 when I had a 1953 Ford with a small block Chevy bored to 301 cu in, turning 8,500 RPM(no misprint) with 1/8" oversize valves. In fact the 427 big block(from a wrecked Corvette) that I had in my 1964 Malibu SS never dropped a valve and it had HUGE stainless steel valves(re: heavy) that saw 7,000 RPM quite often.
#36
there has to be valve heads missing.
That's how that metal ended up in the manifold..
Also looks like the block is trashed too as that's where all the coolant came from..
Looks like that's likely going to be a total loss on the motor..
Sorry to hear your bad luck
#38
So just to be clear.... Is the failure believed to be the same valve issues with the ls7 even with the aftermarket heads on the car or is it attributed to something else?
#39
Well, the heads have to come off anyways youze looks at it. The intake is off so he should be able to see the intake valve through the port. Pull the header off and look into the effected port to see if the exhaust valve head is still there. I'm guessing it's MIA.
