[Z06] ls7 evacuated a piston
#81
I did not remove anything from the bore. I imagine there's a lot of crap in the oil pan. There was a ton in the manifold and a lot would up in cyl 5. It's resting on top of the piston.
#82
Things I'm somewhat amazed by:
The combustion chamber isn't more destroyed.
That rod is still basically in one piece.
Literally there's nothing left of the piston attached to said rod.
The pin is still on the rod.
#87
#88
Looks like the SS valve here stayed in tact during this piston failure. I wonder how many piston failures there have been which destroyed the valve especially the OE hollow stem valve? So what came first...............?
#92
#93
This low mile Z28 also has #6 cyl failure.
http://www.camaro5.com/forums/showthread.php?t=419077
#94
Valve float may have started the complete piston failure.Could have been detonation, could have been a few different things.
Assuming anything at this point is, well...... pointless. Just like the earlier assumptions that the failure was due to a dropped valve.
One of the things I preach around here, and for good reason, is to not assume anything, and take critical measurements. Review your findings.
#95
#96
#97
This is just all speculation. I wouldn't rule anything out but possibly space aliens at this point. I'd have to do a complete tear down and measure/test everything before coming to a conclusion.
#98
Front Page Coverage
Sorry about your engine. Thought maybe some of the front page crowd could help diagnose the problem.
https://www.corvetteforum.com/articl...ystery-ensues/
