[Z06] Headers Install Tips?
Recently ordered Kooks Headers and mid pipe. What problems have people ran into while installing. Any tips?
My friend has a lift, but he won't be available for a few weeks. Would anyone advise against doing it on jack stands?
Just installed my LG's, WOW what a BIT**. Used a lift, but nothing fits right, had to fight with everything. I recommend using the lift, jack stands would really be a fight. Took two of us 8 hrs to install.
Couldn't get Kooks in on driver side. Seems the oil heat exchanger was in the way. I was doing a clutch and was going to do the headers at the same time. But I wanted to get it back on the road so I held off on the headers. A couple weeks ago I removed the oil heat exchanger. I only do dd and drags, no track time. Last week I started installing my wideband to get ready for when I do the headers.
The only extra thing I removed to install my JBA longtubes were 2 coils on the passenger side to allow me to wiggle the header through the top. Driver side fell right into place. Removing the spark plugs would give more room as well.
Did my Texas Speed long tubes on jack stands, the only thing I had to unbolt were the oil lines that connect to the oil pan. I just drained the oil first, un bolted them and swung them out of the way.
-jp
-jp
So, my Kooks showed up and the instructions say to raise the car 24" ....Is this required? most jack stands are 12-18". Gotta go buy new stands if it needs to be 24" so I hope not.
PS, thanks all for your prior comments.
I remove the spark plugs and coil packs off of the rocker covers. I disconnect the coolant temp sensor just in case I bang the header ito it and break it. Firesleeve the clutch slave cylinder line before installing the left side header. Connect the o2 sensors before bolting the headers in place. wiretie/reroute the o2 wires far away from the headers when done. Firesleeve/reroute/wiretie any wires at the starter that are close to the header tubes. Same goes for the wires that go behind #8 header tube. Insulate the starter if it is too close to the header tubes. Add firesleeve to the plug wire boots. There are also two half moon looking bosses sticking out on each side of the bellhousing, removing them gives a little more clearance to fit the headers in place- this depends on who makes the headers.
the kooks 2" were a pita on the pass side. oil lines starter, frame, k-member, block were all in the way i had to move all of those (except the frame) to squeeze it in. the drivers side went right in.
Also running into space issues on passenger side.(3" headers) Driver side went in with a little bit of Tetras work. Passenger side seems to not want to fit any direction. You said you had to raise the block?
Where do you raise the block? the only viable place that I see is the oil sump, but I am scared of cracking it... That isn't a normal place to jack from, but all other spots seem to be frame bars that will just lift the car itself.
Can't go up that high because you will push the intake manifold isn't the cowl.
If you don't have clearance support the block on the bellhousing or pan with a large block of wood and lower the cradle slightly. My ARH 2" went in no issues. Starter had to come out, but didn't mess with anything else.
Doing the 1-7/8 kooks header 3" X pipe. Not sure why I cant fit them in if the 2" header goes in well.
So, i raised the engine and got both headers in. But I seep to keep running into snags every step of the way. My passenger side rear O2 sensor seemes to be wedged somewhere up under/behind the transmission. I can touch the sensor itself but I cannot reach, see, or find the electrical connection so that I can attach the kooks O2 extensions. Suggestions? Or did anyone else run into this?
Keep in mind with my 1 7/8" Kooks headers with catted X-pipe I only needed the white (really light gray) extensions for the rear O2 sensors. The front sensors were fine without an extension. Disconnecting the O2 sensor connectors was the most aggravating part of the install for me.
Good luck.
