[Z06] C6/C6 Z06 CA Owners *Help Needed*
I recently purchased a 2006 Z06 in Texas. I live in California. The guy assured me it was stock, with the exception of an exhaust switch.
He was the 2nd owner of the car and bought it off of his boss, who died recently.
Having never seen up close under the hood of a Z06 I had nothing to compare the stock manifolds to. Turns out the car has headers and no catalytic converters.
Believing the car to be stock, I took it for smog and of course it failed.
The catalyst and OBDII are reading not ready on the failed test.
Hoping to find some help from you guys.
There won't be a legal way to pass with what you have.
Your options are to find a shop and throw some money at them to overlook the issue and to pass you or make your car legal.
Perhaps you can find someone who is willing to trade the OEM manifolds with you. Someone would want some free headers in exchange for their manifolds. Though that does require work and you'll probably need a retune.
Good luck.
Good luck.
Good luck.
Good luck.
Additionally, the tech will do a visual on the car to see if anything aftermarket/illegal are on it. You can pass ECU/OBD2, but fail the visual.
If you can get the car to read as OK via OBD 2 and have a shop overlook the part, then you are OK.
Supporting Vendor
