[Z06] Feedback on LG Motorsports "Super Ram" CAI?
Just wondering if anyone has any feedback or experience with the LG Motorsports super-ram cold air intake? I did a search on here and didnt come up with anything. I know its stupid expensive compared to most other intakes, but looks well designed. Just wanted to know if anyone was running this piece and their impressions?
https://www.lgmotorsports.com/corvet...ai-system.html
I have one and it works very very well. I had other intakes on it, but this one is by far the best.
Forgot about these...looks like a cross between a Callaway Honker and a Vararam. Probably cost prohibitive for most people, but it certainly looks like it would work well. Only feedback I've ever seen is that it clearly can't be used on a car with a stock tune since it causes too much MAF turbulence.
As to the plastic question above from another member, I believe that LG Motorsports mentioned that plastic would deform under aero stress (speed) and so CF was required.
I'm considering this part. Can you be a good chap and direct me to the MAF turbulence feedback please? I haven't read that feedback on this, and I've done a few hours of searching on it.
The MAF turbulence thing occurs on pretty much every CAI that has a "ram air" style intake. Heck, even the "Vette Air" mod or a loose factory radiator shroud (push pins pulled away) can cause a stock air intake to surge (seen many threads on here for each scenario). Look at the Callaway Honker for the C6...they offer two versions, "open element" and a "diffuser panel", which is designed to minimize MAF turbulence on cars without tuning (see links below). The idea is to get smooth linear flow across the MAF to minimize or eliminate turbulence. Halltech was able to eliminate MAF turbulence in their MF103 intake by relocating the position of the MAF sensor...the "MF" stands for MAF Forward, which you probably already know. Precisely why I went with the MF103...I'm stock tune and still under my GMPP warranty.
http://www.callawaycars.com/homepage...inlet-systems/
http://shop.callawaycars.com/Diffuse...-203672743.htm
Josh B. (01-29-2016)
I am a Callaway user (have been since the C5 days), and I also tune my own cars.
I feel the Callaway is a superior product as compared to a Vararam, in both construction materials and design (had one on the old C5 for a bit, I did feel a seat of the pants difference, but I also saw that sand and other debris was getting past the filter / seal - no thank you).
When I bought one for the CE-Z, because (at the time) I wasn't planning on tuning the car until the warranty was up, I made the decision (mistake) of spending the extra 100 bux on the "diffuser" model.
I opened the box, I'm thinking "WTF? What makes this intake awesome is that it feeds directly from the front of the car" - the "diffuser" still lives on the hot side of the radiator shroud, so installed in that way, I don't see the "Cold Air" in CAI.
To summarize, I never installed the diffuser, cut my shroud like it should be. Now, did I have mild surging at freeway / cruising throttle positions, and decel in town? Yes.
I installed a pre-MAF honeycomb (just like GM did on the old C5 MAF's) and it definitely helped. That and a bit of tuning, if it is still there, I don't notice it (and I notice everything).
Bottom line, you should expect the LG might offer some surging, BUT gains are worth it (to me). I would expect the LG to deliver as promised gain-wise.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I don't know if you could do it from plastic and keep the shape of the inlet correct at the nose. one of the reasons we did carbon was to keep it light because of the amount of parts and also to make sure it keeps its form at high speeds.
Former Vendor
Street car guys, nothing to really worry about....most drag cars...not much to worry about. For road racers or standing miles cars, you might want to re-think it.
Former Vendor
As far as turbulence/tuning/MAF issues.
If a cold air intake is worth it, typically you will have to re-tune it to some degree. The ram air intake take a bit more work because you need to get some air speed through them to see what the cars will do at speed.
VaraRam does create a ram air effect but it blocks a lot of the radiator and also does not create that good of a seal through the radiator shroud that you have to cut for the air box to poke through. This reduces the air flow through the radiator and also causes an air leak under the hood and causes lift.
Couldn't agree more...the Callaway Honker was an awesome intake on my C5Z. I had Ryne at CMS tune the car so I never had any surge issues. I wasn't even aware of the diffuser until I heard of surging issues on the C6's. Even though the Callaway disclaimer says the diffuser panel doesn't impede air flow...in my own humble opinion, I would disagree.
