[Z06] Water in oil and oil in air filter
I recently bought a 07 zO6 from the forum I LOVE this car it's a hci car car ran fine all at once it had a misfire so I THOUGHT to check plugs and wires 2wires where cracked so I replaced all of them a d the plugs drove the car car ran great parked it and the next day seen some oil under Front of car so I looked around and found the air filter had oil the checked the oil and the oil had water in it but the car ran better than ever after plug and wire change I'm lost does anyone have any ideas HELP
Oil is or was overfilled.
Know the oil wasn't over filled at all the car has a bigger oil tank and I always check the oil this just happened all of a sudden it was fine one night and I started it the next day and all this happened WTF I'm gonna do leak done test tomorrow but WTF the car has 35,000 miles on it I just don't get it this is my luck
Did you check your coolant resevoir to see if level is droping?
DH
Sometimes you can get condensation in the crank case from a problem with the PCV system. You might want to look at that first. Just how much water did you find, and how did you come to that conclusion?
Yes I checked the coolant and yes the level has dropped so there for the oil tank is over full now Thank you guys I see the was oil coming out of my air filter I did a leak down test today and the #7 cylinder was leaking it was bubbling though the coolant reservoir and then I pulled the dip stick and the oil level was over full so I guess I have to take the head off and hope for the best lol what I don't understand is I never seen any sighs of this happening never ran hot or used coolant or oil I drove the car one night it was fine and started it a day or so later and had a misfire like I said in the first post
Is there any thoughts on that I just hoping it's not a cracked block and if it's a head gasket why I say what is the cause of all this I'm puzzled
Is it possible or likely for head gasket to blow and if so why the car is naturally Aspirated the guy I bought the car from claims it has 704HP at the motor and 612 to the wheels so I'm asking is this a Normal thing to have a head gasket blow or is there something else that caused this HELP SORRY GUYS I KINDA NEW TO ALL THIS SO IM LOOKING FOR A REASON I GUESS LOL
Received 8,928 Likes
Could be cracked sleeve in number 7. Do you remember what the spark plug from number 7 looked like when you took it out? Did you happen to listen for air leaking into the intake manifold when you did the leak down?
Are you getting any loud noises when the engine is running? When the engine in my 08 dropped an exhaust valve it quit running but after sitting for a couple of hours the engine started and ran on 7 cylinders. It made a hell of a noise because the intake valve head had been broken off as the head of the exhaust valve decided it wanted to be in the intake manifold and was jammed in the intake port so it was hitting the piston on every upstroke. Other than the racket the engine didn't run all that roughly.
Bill
Bill
Sounds like a cracked sleeve.
Head gaskets on these cars are damn good. You will take a block out before a head gasket.
If not, you will be doing a very close inspection of the sleeve. Rotate the engine so the piston is all the way down. Clean and inspect the liner visually. A crack big enough to leak that much at room temperature should be able to be seen visually. After that you can magnaflux the liner in place but you have to take precautions not to get the metal dust down to the rings. That's all I got for now.
Think head gasket and remember, a head gasket is only as good as the person who installed it and you did say this engine is modded.
Whenever I hear of a cracked sleeve, it's almost always #7.
