[Z06] How to get 600 rwhp N/A. Need Input
Hi All,
I need your help. I'm trying to reach 600+ rwhp. I'm currently sitting at 555 rwhp. I have ported heads from AHP, Kooks 1 7/8 headers, no cats, corsa exhaust, Halltech 108 and B3 Cam from Race Proven Motorsports.
I plan to add the Fast 102mm Intake manifold and NW 102mm TB, but is there anything else I can do without getting a different cam? If I need a cam, any recommendations with good driveability? I want to keep this N/A.
Thanks for the input.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
This is my typical build on one making 585-615 rwhp.
LG 1 7/8 Super Pro Long tubes
High flow mufflers (Corsa, Borla, B&B, LG...)
ATI underdrive pulley
LG G7X4 or G7X5 cam
LG ported LS7 heads (11.3-11.75:1 compression)
FAST 102 intake
102mm TB
upgraded injectors
cold air intake
Depending on the short block when we start that generally will get them there.
I will say on customers doing the above with a stock intake and TB, you can generally pick up 20-25 with the FAST 102 combo.
LG G7X4 or G7X5 cam
FAST 102 intake
102mm TB
upgraded injectors
cold air intake
Check out the "Mamofied" MSD and NW 102 TB combo from Tony Mamo.
https://www.corvetteforum.com/forums...light=mamofied
LG G7X4 or G7X5 cam
FAST 102 intake
102mm TB
upgraded injectors
cold air intake
LG G7X4 or G7X5 cam
FAST 102 intake
102mm TB
upgraded injectors
cold air intake
-Curtis
Former Vendor
Awesome results by the way!!
Seems like the Mamofied MSD is a good idea. I really wonder if I can get the 40-50 hp from this. I don't really want to change out the cam. Any idea of cost on milled heads? I love the drive ability of the car right now.
If your are going to pay someone to R&R the heads just to mill, I'd say its not worth it unless you were also going to stab a new cam in there. If you can do the work (R&R the heads) yourself, then probably not so bad. If not, I'd say just go with the Tony Mamo MSD and NW TB, and get it retuned. That alone may get you right where you wanted to be with minimal money and effort for such a big gain. If you only get to 590rwhp are you going to be upset? I wouldn't be with those gains and just a MSD/TB swap.
LG cam
How is drive ability with the G7X4 or G7X5 cam. I know the G7XX is the biggest.
Former Vendor
The X5 you start to see more of a change in the power curve and really notice the car above 3000 RPM because of that.
It has been a while since I have driven a XX cam and C6 Curtis might be the better person to ask about that.
That all being said, it is going to depend on who is tuning the car too. A good tuner can really help drivablity on any cam change, and especially a big one.
Former Vendor
Power are in the heads...
With your stock 11.0 CR, you'll be hard pressed to get close to 570rwhp.
I am not sure what are the exact flow figures of your heads vs. what exactly has been done to them, but if you want close to or 600rwhp, you may need to revisit them again while shooting for CR around the 11.7 to 11.9 range to run on pump 93oct.
Fueling will be key; bigger injectors should be in your recipe along with great tuning. You can get there on pump - much harder on 91oct, but much easier with E85, race gas or by implementing a pump/meth combination.
I'll be real with you, you're now sitting at 555rwhp and looking for 600 to 600+ to the tires...you will have to up the game to gain that extra 45+ rwhp no matter which fuel method you choose.
Hope this helps
Thanks,
Carlos
Hope this helps
Thanks,
Carlos
