C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] new crank bolt install.........follow SM or ATI instructions
Old 01-30-2016, 11:25 AM
Cman01
Cman01's Avatar
Default new crank bolt install.........follow SM or ATI instructions
The ATI balancer will be installed soon, I have different instructions from the GM SM and the instruction sheet with the ATI. I am using a NEW GM crank bolt.
The difference comes after you use the old bolt and torque down to 240 ft/lbs and remove.
The ATI instructions say torque new bolt to 37 ft/lbs then go another 140 degrees as your final tightening spec. The GM SM instructions say 37 ft/lbs then go another 230 degrees as the final tightening spec.
So which should I follow?
Old 01-30-2016, 12:38 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
You wouldn't catch me putting 240 ft/lbs on a used TTY bolt - Yes, I know what it says in the SM - use old bolt..
I would press the balancer on to the crank to the proper depth (that spec should be in your SM) with your tool, then install the new bolt.
Spec is 2.4 to 4.48mm crank recess.
And if you are using the GM bolt, then logically you should follow GM's procedure. If you had an ARP bolt, follow their process.
But I am also the guy that pins balancers to cranks just to avoid all this locking flywheel / high bolt Tq crap, so..
FYI - my SM says Tq to 110 - loosen 360 degrees - Tq to 59 - tighten past 200 degrees.. Now, doesn't pinning the crank sound attractive?
Old 01-30-2016, 03:49 PM
Cman01
Cman01's Avatar
The way I see it, the balancer has to line up with your pullies so your belts will line up properly and not get thrown, so if I press the balancer until the AC pulley on the balancer lines up with the belt tensioner for the AC compressor then the balancer is pressed on enough.
Wish I could pin the crank but no way I'm going to be able to do that in the garage so the ATI will just get pressed on for now.
Old 01-30-2016, 05:48 PM
Dan_the_C5_Man
Don't try to eye-ball 2mm from the top of the motor - from all your posts, you seem to be very interested in doing things "by the book" - that includes measuring the crank snout recess.
Remember, there is a taper involved here; the only thing keeping it from spinning (and coming loose) is the press fit.
Standing over the top of the motor and eye-balling the pulley alignment is not the way to go.
Old 01-30-2016, 05:51 PM
wjnjr
wjnjr's Avatar
Instructions for installing ATI LS Superdampers:
http://www.atiracing.com/instruction...LS7-Damper.pdf
For more info call ATI tech help @ (410) 298-4343
Old 01-30-2016, 10:08 PM
Mike44665
Support Corvetteforum!
Mike44665's Avatar
Purchase a good, USA made installation tool. You can unload it here. The cost to replace what could be destroyed if you don't have a real good engagement of the crank threads before you really have to crank on it, would be insignificant compared to the cost of the tool. Although it may sound like a quick take off, put new on, deal. Anything that goes wrong is very big bucks.
Have you considered how your going to keep the motor from turning?
Old 01-31-2016, 04:33 AM
Cman01
Cman01's Avatar
I have the damper install tool and I'm also using a flywheel locking tool to keep the crank from turning.
Old 01-31-2016, 06:00 PM
Cman01
Cman01's Avatar
ATI is on. Followed ATI instructions with new GM bolt.
Really no f-ing way in hell anyone really can go 230 degrees with the new bolt after torqueing to 37 ft./lbs. so I went the 140 degrees (barely made it there).
Pullies lined up perfect (yes I got the proper depth also from the edge of the crank snout to the damper).
Old 01-31-2016, 09:46 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
Looks like you read the service manual completely wrong. It tells you to tighten the old bolt to 240 lb ft (not degrees) then install and torque the new bolt to 37 lb ft and an additional 140 degrees after that.
The end result was the same but consider yourself lucky you didn't break something if you actually tried to turn that bolt 240 degrees.
Old 01-31-2016, 11:45 PM
Dan_the_C5_Man
..And my 2011 SM says something completely different than above (I posted it earlier).. Seems as if GM applied some lessons learned through the years (and process improvement is always a good thing).
Old 02-01-2016, 04:31 AM
Cman01
Cman01's Avatar
What year is your car? Seems every year there's a different procedure to achieve the same thing, and I didn't read my sm wrong.
After doing the 240 ftlbs with the old bolt and remove the new bolt goes to 37 and then turned an additional 230 degrees.
I post up pics later of what it says in my 09 sm. I know what I read in there.
Old 02-01-2016, 05:08 PM
Cman01
Cman01's Avatar
from my manual LS3 instructions:
LS7 instructions:
LS9 instructions:
Old 02-02-2016, 07:50 AM
Kenny94945
Kenny94945's Avatar
Interesting thread.
In for answer.
Opinion:
All three instructions guides in post # 12 differ.
Is it because each one of the three refer to a different engine?
Are the instructions different because each engine has a different crank shaft?
Could be on going improvements by GM from research in their instructions.
Can a forum co-member get today's (Feb 2016) dealership on-line current instruction?
My LS2 2005 SM pg 6-88 says:
(Note balancer position, weights and etc before removal)
Install balancer with tool, remove tool.
Install old bolt and torque to 240 ft lbs, remove old bolt.
Measure recess.
Install new bolt toque tighten to 37 ft lbs first pass.
Second pass tighten to 140 degrees.
Reinstall starter etc PLUS perform Crankshaft Position System variation lean procedure.
To new crank bolt install.........follow SM or ATI instructions
Quick Reply: [Z06] new crank bolt install.........follow SM or ATI instructions
