[Z06] what causes a lifter to turn
The following 2 users liked this post by 08mojo:
1badtantrum (02-15-2016),
SteveDoten (02-10-2016)
Anything that can be done to avoid such things? About to put mine back together - everything is fine, but just had a buddy lose one on his ctsv
And if not link style lifters, at least buy some new lifter trays.
When disassembling red threadlocker the process is a little different than for other threadlockers. The key is to apply localized heat greater than 550° F. Then, once the threaded assembly is hot, the bolt can be unthreaded. Without applying heat to the assembly, it's likely that over time, a bolt would break before coming loose.
Watch this video for a demonstration on removing red threadlocker:"
http://us.henkel-adhesives-blog.com/...-Threadlocker/
I used a torch after I broke the first torx driver. Could not get the bolts hot enough, as there is simply too much heat transfer to the block.
Cam bolts might be easier to remove, and you could get some heat on them. I'd still use blue, if I wanted to. I see no need for it though, as long as you use the proper torque. Come to think of it, I don't recall ever using Locktite on a cam gear bolt, ever.
Regardless, Blue Locktite works just fine. Red, I only use it if I know I can get some good leverage on a fastener, or use heat on it.
I did blue locktite and a cam gear bolt lockplate = 100% guarantee cam won't walk in the block.
Red locktite is overkill on that area and needing to heat it up to remove it makes me cringe. Heat is good in some areas but engine block/cam gear areas is iffy using heat to remove fasteners. MO
