[Z06] help me choice valve for c6 z
i got 08 c6 z06 for couple year ,but after i read valve train problem on zo6 i dont want drive car .but i still love the car.i hope someone here help me keep my z back on the road
i plant take cylinder head out to my local machine shop for they replace valve guide and exhaust valve,valve spring
could you give me parts number for ss exhaust valve
what type on valve guide parts number
on valve spring can i used old one or buy new one at gm .
i really need friend here help .thanks
Definitely don't drive it...don't even start it up...it will for sure blow up.
Whatever head builder you go with will have all the right combos to set you up. Look into American Heritage...forum vendor here with plenty of right options.
SteveDoten (02-10-2016)
I would take the heads off and inspect them first
Then u can get what you need.
Mine was an 06 and it was not really out of spec but as I went on to put cam and stuff I put Manley ss exhaust valves but kept the titanium Intake valves as they are not problematic.
Changed the springs also speak to Brian Tooley racing he's a good guy and there combos are good.
As was already mentioned, if you live in the US you should call these guys to discuss your options.
http://www.americanheritageperformance.com/
Supporting Vendor
Received 1,012 Likes
wcch does nice work but there are fundamental differences between them and us (American Heritage) when it come to the LS7 Heads.
We are not a big fan of bronze guides when running stock rockers. In fact we stopped running bronze guides in LS7 heads years ago. If running a shaft mount rocker then a bronze guide will be fine but most people run stock rockers and the stock rockers side load the valve (due to their design). Bronze guides do not hold up that well when exposed to excessive valve side loading. We use our hardned Powder Metal valve guides or our proprietary MoldStar90 valve guides (same material used in F1 and Indy Heads). Both alloys (PM and M90) stand up very well to valve side loading.
We also hold our machining tolerances to a very very tight German standard. We are not a high production shop we hand port via our superflow600 flow bench and measure run-out on every valve job (less than .001" valve seat run-out even with a large 2.2 inch valve. Far exceeding industry standards).
And yes we do ship worldwide... Canada, Europe, Australia, UAE. ect...
That being said, had my builder asked me who to go with for head porting (he didn't, lol), I'd have suggested either Tony Mamo or AHP.
Katech: "hey, your operation at AHP is so new school, with emerging tech like hand porting, can we send you cylinder heads for use on our OEM grade vehicle packages? We don't take it lightly when we put our name on a product, so your company was at the tippy top of our list."
AHP: "No, sorry, we are limited production only. Our hand porting tools are powered by our love for the LS7, the little things like new paint marks on individual components make this shop the very best there is. Sorry, we won't be corporate sellouts to your OEM supporting Motorsports company, no matter how badly you beg us."
Katech: "Fine, AHP. I see the light now. We will just have to go with our fifth choice, WCCH. Their CNC machines and proprietary cylinder head developments are a little behind the times, but we will suffer your rejection with dignity, so long as wind of this conversation never gets out..."
REDZED2 (02-13-2016)
Exactly. I came across a private conversation between AHP and Katech proving exactly this point. A conversation Katech never wanted leaked to the general public.
I think Katechs reputation speaks for itself......they have done more for the LS7 and C6Z than AH ever has or ever will.....
I'm kinda confused about your last two responses though. Are you supporting WCCH or not? First post would suggest you do, then this one above leaves me confused..?
There is a high level of sarcasm in his second post that you seemed to have missed.
Josh B. (02-11-2016)
Just stirring the pot in good fun. Joshing you.
