C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Failed COMP CAMS Trunions
Old 09-23-2016, 02:02 PM
  #81
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I actually paid less than that but talk to vendors and see what deal you can get. Even at 160 well worth it.
Old 09-23-2016, 02:41 PM
  #82
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Originally Posted by blackdak318
I just bought a used 440 LS7 that has the COMP trunion upgrade. I'll be checking them in the next few weeks and report back. I'm not expecting good things though.
So are people going back to stock or with CHE/Straub/BTR? Is there any issue with the stockers?
What's your cam profile like on that 440? Who did the build, and what does that build consist of? Maybe looking into a roller setup (depending on your build) could be the better move?
Originally Posted by tdeweese
I agree, I posted this thread. I put it out there as information that like mined people could use to make their own decisions. Take it with a grain of salt, but I had to spend thousands of dollars and months of my time to correct my motor from the failure. My intent was to provide this information to people who may consider this as and "upgrade" Its their money and their motor!! Only upside is I have a really badass motor since the rebuild!!!
Great thread OP. If there's a $120 part that has a known propensity to fail prematurely; I certainly wouldn't allow it to stay in my $15K motor.
Old 09-24-2016, 02:35 PM
  #83
Radical05
Radical05's Avatar
I opened up the valve covers and looked at the rockers with 500 miles on them, not track driving but spirited and I see absolutely nothing meaning no metal particles that would indicate anything is happening. Will check again at 1000 miles and then actually open up one to see if there is any wear on the trunion. If it was wearing like others had I would see some particles around the rocker.
Old 09-26-2016, 09:28 AM
  #84
blackdak318
blackdak318's Avatar
LS7R cam. Central Texas Machine did the build. Its 4.130 x 4.100. Compstar crank and rods, Wiseco 2.8cc dome pistons. RPM CNC'd heads. 12.2:1 compression. It is a lightly used motor I bought from another member here. Haven't fired it yet, still working on getting it in my car. I've spent enough on this motor/swap already. If I find wear when taking these apart, I'll just be going with the Smith Bros bushing kit.
Old 09-27-2016, 08:17 PM
  #85
zulatr
zulatr's Avatar
You say talk to the vendors, you mean the texas speed type, or who?
I don't think you're talking out of turn to offer who you bought from or spoke to about the parts...
Old 09-27-2016, 08:57 PM
  #86
Unreal
Unreal's Avatar
Any vendor that sells Smith straub or btr parts. Joe at Cpr typically has great prices.
Old 09-29-2016, 07:29 PM
  #87
MTPZ06
MTPZ06's Avatar
Yet another documented Comp trunion failure.
https://www.corvetteforum.com/forums...eo-inside.html
Old 09-29-2016, 10:59 PM
  #88
Les
Les's Avatar
I listened to the video when it was posted in that thread and really didn't think it could be an exhaust component tapping somewhere. However, as hard as it is to diagnose sounds on a laptop I kept silent.
Well, I'd already seen enough to know that I'd never put them on my engine. This is just more proof for the doubters to ignore.
MTPZ06 (10-01-2016)
Old 09-30-2016, 08:15 AM
  #89
Unreal
Unreal's Avatar
Another 2-3 failures on the camaro board.
Old 09-30-2016, 11:34 AM
  #90
jarcher
jarcher's Avatar
I just pulled a rocker off my motor this week trying to hunt down a bad noise. premature wear on Comp Cams trunnions with 3000 miles on them. Straub Technologies kit is on route
Old 09-30-2016, 12:08 PM
  #91
Michael_D
Michael_D's Avatar
The rocker would need to be disassembled to determine anything of value. I thought you were an engineer?
No4Play (12-03-2016)
Old 09-30-2016, 12:38 PM
  #92
Unreal
Unreal's Avatar
As Michael said, you need to pull one apart. I did the same thing at 18k miles, said the same thing. Then I opened one up, and it was trashed. Unless you remove snap rings and push one out, you may not see anything.
Old 09-30-2016, 09:15 PM
  #93
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,087 Likes on 573 Posts
Everybody's an engineer around these parts...
Old 09-30-2016, 10:05 PM
  #94
Unreal
Unreal's Avatar
I'm an engineer too
Old 10-01-2016, 02:47 AM
  #95
MTPZ06
MTPZ06's Avatar
Old 10-01-2016, 02:54 AM
  #96
REDZED2
REDZED2's Avatar
That is correct Alex! Hey first start small with tonka trucks, then you can build a death star to conquer the rebellion using those garbage comp trunnions!!!!
Old 10-03-2016, 06:31 AM
  #97
Radical05
Radical05's Avatar
Obviously you cannot read very well, I said I only checked mine and will open up to see later on. Every post that someone puts in here or somewhere says they see metal by the side area clip. I'm not going to open them up with 500 miles on them when there is nothing to indicate anything is happening at this time.
To Failed COMP CAMS Trunions
Old 10-03-2016, 08:05 PM
  #98
Radical05
Radical05's Avatar
Where specifically is that / those post at so I can read them and update my info on the issues they had and was it 2 or 3 or 1 or 4 different post?
Old 10-04-2016, 07:31 AM
  #99
Chance575
Chance575's Avatar
I have around 20k miles on mine with no problems, WCH stage 2 heads and a .650 lift cam
Old 10-04-2016, 08:06 AM
  #100
Unreal
Unreal's Avatar
Post a picture of them. Like I said above, I said the same thing until I opened one up. Did you actually open them up and inspect, or just saying that because the car is running?
Quick Reply: [Z06] Failed COMP CAMS Trunions
