C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] C6 z06 clutch noise help please!!!!
Old 04-14-2016, 06:00 AM
daniells7
5th Gear
daniells7's Avatar
Default C6 z06 clutch noise help please!!!!
Hello everyone. I bought my 09 c6z 2 Months ago it's has 35k miles. its making a knock noise. every time I pull it out of gear l And release the clutch. It only knocks when pulled out of gear into neutral is this a comon problem ? obviously it's something to do with the clutch. but the vehicle runs fine except for some bouncing between shifts. don't think its my driving I had many manual vehicles so. if anybody has this same problem or knows about the problem please help thanks have a nice day
Old 04-14-2016, 08:51 AM
double06
double06's Avatar
Default Do you have a stock or aftermarket clutch?
Does the knock only occur when say you are at a stop light and you pull out of gear and your foot is off clutch pedal? If this is true and you do have an aftermarket clutch you have one with a light flywheel and they are known to "chatter" at a stop light with your foot off clutch pedal.
Old 04-14-2016, 10:11 AM
Landru
Landru's Avatar
Received 1,047 Likes on 821 Posts
Originally Posted by daniells7
...I bought my 09 c6z 2 Months ago it's has 35k miles. its making a knock noise. every time I pull it out of gear l And release the clutch. It only knocks when pulled out of gear into neutral is this a comon problem ? obviously it's something to do with the clutch. but the vehicle runs fine except for some bouncing between shifts.
No help but I'm wondering if it's clutch related, a'tall.
Your description of a "knock" bothers me, never heard the term related to clutches et al.
Any code(s)??
Any parts store will have an OBDII reader, will plug-in & tell you if there're any registered.
IF there is it may very likely lead you to the issue. Nothing to lose.
Otherwise it's off to the dealer. G/L
Old 04-14-2016, 01:22 PM
daniells7
5th Gear
daniells7's Avatar
No codes no engine light
Old 04-14-2016, 04:09 PM
NiteriderFRC
NiteriderFRC's Avatar
Drivetrain on these cars tend to be quite noisy. I'd also Look into faulty hydraulics. GM put out a voluntary recall on the Clutch Master Cylinder late last year.
Old 04-15-2016, 08:17 AM
Jerry's aclt1
Jerry's aclt1's Avatar
I also have a 2009 Z06, but have not experienced what the OP has explained.
Old 04-19-2016, 09:54 AM
Landru
Landru's Avatar
Would a failing torque tube bearing cause a clutch to clunk?
JMHO but this needs to be looked at by a Corvette pro. 'Clunk' has to be duplicated for a tech, once isolated which way to aim is known & can be dealt with.
G/L man, take it to a good indy shop ideally specializing in Corvettes & specifically C6. Have to learn for sure source of this clunk or you'll be left chasing rabbits down holes time-wise & dropping $ at every step along the way. Someone can/has to properly diagnose this up front & personal.
Old 04-12-2017, 02:54 PM
sushistrip
sushistrip's Avatar
Did you ever resolve this issue? I'm having nearly identical symptoms on my 2011 Z06
Old 04-13-2017, 07:10 PM
phipp85
phipp85's Avatar
The problem above sounded like an aftermarket solid hub clutch like someone else stated.
Stock clutch on yours?
Old 04-13-2017, 07:52 PM
Undy
Undy's Avatar
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes on 578 Posts
A lot of the dual disk clutches have a rattle/knock at idle in neutral. Perhaps your Z has had a clutch change?
Old 04-13-2017, 11:29 PM
sushistrip
sushistrip's Avatar
Aftermarket clutch on mine. LS9 clutch and aluminum flywheel. I started it up the other day and it made zero noise on cold start. After driving it around, get back and let it idle in the garage I could very faintly make it out. Put my head on the ground and tried to listen for it under the car and couldn't hear anything.
To C6 z06 clutch noise help please!!!!
Quick Reply: [Z06] C6 z06 clutch noise help please!!!!
