[Z06] Mamo ported MSD gains
They Deff work that's for sure. I haven't seen a more consistent accurate 620+ HCI package out there Rep that has gone 140+ on multiple cars
Tony, can I ask a quick question.
I have been reading a lot of these type of threads and remember someone asking about a specific part
of the tuning program relating to the volume of each manifold being different and this needed
changing for the tune.
After seeing how much material you remove from the manifolds I was wondering if you know if the porting
would change the volume significantly to need this adjusting in the tune.
Do you know the "after" volume because you seem to take loads out.
Wow great gains! Im excited to get mine installed. Tony put a package together for me that is going to be killer. Mamofied TFS heads, mamofied msd, with a solid roller. Should be insane!
I have helped a few dozen guys at this point and this mod is as straight forward as any other mod that changes the amount of air the engine is able to process....its very straightforward from the point of tuning for maximum gains and the cars drives great after the install.
In fact I spoke with one customer last weekend who commented the car actually drove smoother after installing the ported MSD and that even from the factory it always had a slight stumble/miss at an idle. He said it actually smoothed out after the MSD was installed. I thought that was interesting
Anyway....hope this helps
-Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Da Z06 (05-26-2016)
