[Z06] Good street tires - Invo, PSS, PS2, NT05?
#41
IMO and from what I've seen in real life...the RE11 is a bit more extreme than the PSS. I know guys with Z06s that track and don't track on RE11s and get about 11,000 miles out of them. They are a fairly soft compound tire and between those the PSS...I'd opt for the PSS all day on a 100% street car.
Do you have any direct comparison in feel between the PSS and the RE11s? Again, I'm not so concerned about the last .01G of lateral grip, as I am about the crisp feel of the steering with the tires.
#43
Now that autocross SCCA stock classes have to run 200 treadwear rated tires you can pick from their favorites if you like. Rival S and Bridgestone RE-71s. But then again serious competitors need to run 18s to get the tire sizes they want. My preference are the MPSSs.
#44
So I ordered the RE-11s. Hopefully I'll have them installed today or tomorrow. The more reading I did (opened up the search to all cars with these tires, not just Corvettes) the RE-11s seemed to fit what I wanted in a tire better than the PSS...I don't drive in the wet, non daily driver, only drive in fair weather. I want an aggressive stiff sidewalled tire that gives me very responsive steering...the RE-11 seemed like the better choice (plus they were $150 cheaper). They also seem to be getting phased out, so this is probably my last chance to own them. I'll give me feedback once they are on the car.
#47
#48
I've run Invos and PSS. Both are more quite than the F1's and both ride smoother. I had about 20k miles on the Infos when I picked up a bolt which ruined a front tire. I'm guessing I still had another 10k miles left in them. I switched to PSS which I've got about 1500 miles and they do hook up better.
If all I needed was a tire to cruise with the wife, I'd probably save some money (because I'm stupid... I mean cheap) and buy the Invos. In fact I put them on my Wife's BMW 650i (because I'm stupid......I mean cheap, that's why she drives a 650 instead of a Malibu).
#49
These tires continue to impress me with each time I drive the car. I bought these in the winter so I never got to test them out in warmer weather and now that summer is on it's way I gotta say that these tires do live up to the hype!
#50
I'm not sure. As of two weeks ago, they were on backorder at tirerack, they were discontinued at Costco, and I got the last set at BJs. They were installed (by a different shop, because BJs called and said they couldn't install them) two Thursdays ago.
So far (25 miles on them) grip is great and response is very good (for a full tread tire). I can get on it in 2nd and not worry about wheelspin. Even hooks first pretty well. Lateral grip is great and response is very good. I feel a little tread squirm on violent lateral maneuvers, but it comes with 9/32s tread depth, so it will only get better from here.
#51
When I was tracking...I knew a base C6 owner who only ran RE11s. He was going through sets like they were going out of style...loved them....but couldn't get much more out of them than 4-5 weekends (characteristic of a R compound). I kept telling him, that you might as well go full R compound at that point, but he was convinced the tires were that good..as in comparable to a R888.
#52
RE11s are grippier and more responsive than the PSS.
RE11s have stiffer sidewall than the PSS.
RE11s will last longer than the NT-05 but shorter than the PSS.
RE11s are most comparable to the NT-05s, with slight improvements in grip and tread life (NT05s have 7/32 tread depth).
Time will tell if I will be happy with the RE11s, but so far so good. They are not as responsive as the stock Supercars which had 6/32 tread depth left, but I'm betting that will change as they wear.
#54
So here's an UPDATE:
I have about 100+ miles on these tires now, and have a better feel for them to give an adequate initial review.
First and foremost, they definitely grip! Went for a spirited run up and down my favorite stretch of roads and they performed excellent. I saw 1.05G on the HUD before getting tire squeal. These tires are very neutral and predictable. In a straight line, these tires hook very well. Rolling into the throttle in first gear at 3K+ rpms will spin slightly and bark 2nd. Rolling into the throttle in 2nd hooks without an issue. There are a very soft compound and ride incredibly quiet and well. The ride quality is actually more quiet and comfortable than I prefer. I didn't have a problem with the stock runflats in terms of ride quality and noise, my problem with them was their unpredictable grip, atrocious wear-life, and weight. But the RE-11s make the runflats seem like they were made out of wood. Let's just make this clear right now, any tire on sale today is going to make the supercar runflats seem at best, like they are made from some other material than rubber, and at worst catastrophically dangerous.
The only complaint I have right now, and it's a complaint that I will have on basically every set of new tires short of Rivals and cup tires, is the tread squirm. These are full tread tires 9/32". I'm certain they were firm up as they wear, but I don't like the squirmy feeling at high speeds. The tires certainly grip, but the immediacy of the steering with the runflats, or my C5Z with bald runflats or Rivals is not there. I am glad I went with the RE-11s over the PSS, because based on all my research it seems the PSS has a softer sidewall in comparison to the RE-11s. If I had bought the PSS, I surely would be experiencing the same sluggish steering (PSS has 10/32" tread depth), I would have buyer's remorse not going with the more aggressive "extreme performance" tire.
Overall I'm very happy with my choice and will be giving updates as they wear in and I put more miles on these. Unfortunately, there doesn't seem to be too many reviews for the RE-11s for Z06s (and a some Corvette/muscle car people seem to think that handling XXX RWHP is the only way to review a tire) so hopefully this will serve to be informational for Z06 tire buyers.
#55
Interesting. I opted for the extreme performance tire (RE11) over the max performance tire (PSS) because it suited the way I will be using this car...sunny days, over 50 degrees, spirited drives. I basically treat this car as a 4 wheeled motorcycle. So I was looking for sticky tires that give good driver feedback. I didn't get too much info on this forum for the RE11 vs PSS. However, once I broadened my search, I found the following info:
Regardless, your Re11's should give you good service and should be fine for the autocrosses.
You mention the Rivals, but I don't see that they are available in the stock Z06 size for the rear, only go to 18".
#56
Say what you will about the Invo's, in my experience with them (2 sets on a Z06 and a set on a base C6) they have been great. Quiet, comfortable and more than enough grip for any type of street driving.
Price out a set of 345-25/20, they are not cheap.
In any case, I have had zero issues and don't hesitate to recommend them.
#58
Glad to see your review Mig, my Invo's are getting bald fast and will need a new set pretty soon. I see the RE11s are out everywhere, which means you were right and no longer in production. I do a ton of spirited driving and wanted to do the RE11s as they seem to do what I'm looking for but since they're out of production, are the PSS the next best option? I know Dave is a tire expert, so maybe you can throw your 2 cents in here too.
#60
It's certainly possible. I'm just going by what I've read on the internet PSS vs RE11...read reviews for 370Z, Porsche, G8, Mustang, M3 bimmerpost etc. The rule is really to go for the newest tire that's available, because the newest tire is almost always best. Tire compounds are getting better and better every year. I wasn't crazy about the RE-11s due to their age (released in 2009). PSS is certainly the better all around tire...I'm fairly certain of that.
Hopefully! Now it's time to dial in the suspension.
I ran the Rivals on my 2004 Z06. I sold that car back in March. I wish the Rivals were available in C6Z sizes...it woulda been a no brainer for me.
Oh and BTW for all those running Invos...I have no personal experience driving with them. But my buddy has a 2011 GS vert and has them. They are leaps and bounds better than the supercar runflats...obviously lol. They feel pretty good on his car and his car certainly handles well and puts the power down. He raves about them! Especially because he paid like $1000 installed. There are a lot of negative reviews about the Invos but I can't really say if it's justified or not. From the passenger seat, they seem like a decent deal.
