C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Another HCI build with K501, E85, and Tony Mamo MSD
Old 09-21-2016, 10:09 PM
  #101
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Did you atleast grind off an area since the alternator grounds through that bracket? Coating it could cause issues if you didn't clear some area of bare metal off FYI.
  #102
FNBADAZ06
FNBADAZ06's Avatar
Should see some numbers soon. I'm not a big fan of comparing dyno charts, especially when they come from different dyno's and geographic areas, but my build mimics what Jim Hall's has on his car. I'm only 12.0:1, where he is a 13:1 car. I'll be on E54, where he is on E85. I do have the Mamo ported MSD as my only change...Jim's is un-ported.
I'm in hot AZ too .
I'm guessing high 580's , +/- 10 rwhp , corrected SAE.
  #103
FNBADAZ06
FNBADAZ06's Avatar
Originally Posted by MTPZ06
Ceramic? Like the headers?
Yes
Old 09-21-2016, 10:10 PM
  #104
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Originally Posted by FNBADAZ06
Yes
Cool...good idea.
Old 09-21-2016, 10:12 PM
  #105
FNBADAZ06
FNBADAZ06's Avatar
Yes, all 3 mounting pads where ground to expose the metal underneath, specifically for the issue you mentioned above.
Old 09-21-2016, 11:16 PM
  #106
AzDave47
AzDave47's Avatar
Received 4,493 Likes on 2,590 Posts
Very nice, Victor
FNBADAZ06 (09-22-2016)
Old 09-22-2016, 12:47 AM
  #107
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Nice motor **** Vic. Looking forward to seeing some good numbers.
Old 09-22-2016, 08:12 AM
  #108
FNBADAZ06
FNBADAZ06's Avatar
Hey, T-Buc.....how's it going ? Good to see you're still around
Old 09-22-2016, 02:50 PM
  #109
FNBADAZ06
FNBADAZ06's Avatar
It's ALIVE !!!!!
Now, for the tune modifications
Old 09-22-2016, 06:59 PM
  #110
FNBADAZ06
FNBADAZ06's Avatar
Old 09-22-2016, 11:05 PM
  #111
Buccaneer
Buccaneer's Avatar
VERY NICE Vic!
Yeah, I'm still around, I don't hang on ACE anymore though. Getting ready to leave again in Dec.
Old 09-23-2016, 12:54 AM
  #112
AzDave47
AzDave47's Avatar
I'm in hot AZ too .
Victor,
If you are dyno'd on the same one I was (probably will) and with your E54 and ported MSD, you will be 620 SAE rwhp, on that dyno. I am not suggesting it is stronger than Jim's on the different dyno.
I don't remember what headers your car has.
Old 09-23-2016, 08:04 AM
  #113
FNBADAZ06
FNBADAZ06's Avatar
Originally Posted by AzDave47
Victor,
I have the B&B 1 7/8th on my car, and both Jim and I run the same Akrapovic EVO exhaust. I'll dyno on my 335/25/20 and my heavier 20x12.5 wheels...not sure if Jim dyno'd on his 19" carbon wheels or not.
If my car does show the numbers in the lower 600's, I'll see what my trap speeds are to back that number up. Just as importantly, I want to see what my uncorrected numbers are as that is the truer number of how my car will operate in our climate
Can't remember, but are you catted on your car or no cat ?
Old 09-23-2016, 09:32 AM
  #114
AzDave47
AzDave47's Avatar
Pfadt 1 7/8" headers and their catted x-pipe. I was 602/492 SAE corrected on that Valley dyno and ~ 572 uncorrected at 93*. Power peak was 7100 RPM with MSD unported and K501. The K501 typically peaks at 66-6700 RPM w/4 into 1 headers.
FNBADAZ06 (09-23-2016)
Old 09-23-2016, 10:42 AM
  #115
FNBADAZ06
FNBADAZ06's Avatar
It should be on the dyno Tuesday or Wednesday for my retune.
Unfortunetly, I did not use this particular dyno on my original Katech 110 setup...so the comparisons between those runs won't be a direct apple to apple comparison, and we were unable to dyno the car prior to beginning this build for a baseline.
Old 09-23-2016, 11:50 AM
  #116
AzDave47
AzDave47's Avatar
Will this one be at ProDyno and tuned by NicD? If so at least the SAE will be a good comparison between your build and mine.
I had my stock LS7 dyno'd at both Extreme Speed and ProDyno in the Valley 4 years apart and they got the same 469 SAE numbers.
Old 09-23-2016, 11:56 AM
  #117
FNBADAZ06
FNBADAZ06's Avatar
Yes, NicD and ProDyno.
I'll start a new thread when the numbers come in
https://www.corvetteforum.com/forums...o-results.html
AzDave47 (09-23-2016)
Quick Reply: [Z06] Another HCI build with K501, E85, and Tony Mamo MSD
