[Z06] Have BB Fusion 3" exhaust with no cats? Step in.
Alright guys. Here is an update. I do have the "Gen 2" if you will. The strange part is that the outlet main pipe is 3". Now I'm curious what the changes for the gen 3 were.
I see several people saying the Gen 3 is where its at and am interested in going that route to see if I like it. Realistically what is the fusion exhaust I have worth? It has roughly 5k miles on it.
jp_tt_awd (05-26-2016)
I would like to know the difference between Fusion II and III also but no one seems to have that answer including the vendors... I read something to the effect that if your car doesn't have 700+ horsepower the III will cost you power. I have a problem believing that.
I have the III on a H/C catless setup and its LOUD with the flaps open and drones horribly at certain RPM. Doing WOT through a tunnel or under a bridge will make your ears ring. With the flaps closed its fairly quiet with the windows closed (tire noise is MUCH MUCH more noticeable), though certain RPM still drone a tiny bit and its easy to drive around it by going faster or dropping into 5th. I have an 06 so it has less sound deadening than the later cars. I previously had the B&B bullets with the same H/C setup and it droned just as bad and it was a bit quieter than the III with the flaps open.
What brand and size rear tires are you running?
