C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] AC/Heater fan noise
Old 05-22-2016, 11:53 PM
meanjoe
Support Corvetteforum!
meanjoe's Avatar
Default AC/Heater fan noise
My Z makes a bunch of noise out of the A/C vents when I have the Fan at full speed. Sounds like a small tornado. It gets less noisy when I put it in fresh air mode "Non recirculating" Am I the only one with this problem or is this just the way the car is?
SOLVED See post #21
Old 05-23-2016, 01:18 PM
meanjoe
meanjoe's Avatar
I would just like to know is the wind noise coming out of the vents is normal? Mine is very noisy.
Old 05-23-2016, 03:23 PM
390amx1
390amx1's Avatar
Mine is very loud from medium to high fan speed. So much that when I first noticed it I thought something was wrong until I turned the fan down. I suspect its normal.
Old 05-25-2016, 01:07 AM
meanjoe
meanjoe's Avatar
Thanks for the info. Anybody else care to comment?
Old 05-26-2016, 12:55 AM
meanjoe
meanjoe's Avatar
I'm trying to figure out if there's a fix for this or if I'm stuck with it like it is.
Old 05-27-2016, 12:53 AM
meanjoe
meanjoe's Avatar
ttt
Old 05-27-2016, 12:59 AM
meanjoe
meanjoe's Avatar
I would like to thank 390 AMX for his response.
Old 05-27-2016, 02:56 PM
Mike44665
Mike44665's Avatar
I'm going to pull mine out this weekend. It may just be leaves or something. I let you know what I find.
Old 05-27-2016, 05:23 PM
meanjoe
meanjoe's Avatar
Thanks! I'd be interested in what you find.
Old 05-28-2016, 11:16 AM
Mike44665
Mike44665's Avatar
Well I can't believe it, but..... The motor bearings felt fine. Nothing in the blower housing, no contact marks. As usual you could get it apart to put a drop of oil on the bearings, but you wouldn't be able to use it again. I used Windex and the little brush to clean off the dust, ran some water, carefully, to get the Windex and loose dirt off, blew it dry, put it back in and it's QUIET. The spear goes into a hole on the firewall, pull down the carpet, three screws are 7/32 hex head, unplug motor before you try to drop it out.
Old 05-28-2016, 01:09 PM
dr_whigham
dr_whigham's Avatar
I noticed mine makes a lot of noise as well; 2009 Z06. It's quite irritating to be honest. So the solution id to pull it out and clean it? It souns like its a VENT noise issue, not the fan though.
Old 05-28-2016, 09:04 PM
meanjoe
meanjoe's Avatar
I agree. I'm not getting any motor noise, it's more like being in a big wind tunnel.
Old 05-29-2016, 07:53 AM
User Omega
User Omega's Avatar
Stupid question but have you checked the cabin filter?
meanjoe (05-30-2016)
Old 05-29-2016, 11:38 AM
dr_whigham
dr_whigham's Avatar
No...
Valid point though, and I'm sure mines never been changed and needs to be done anyway. Thanks for the suggestion
Old 05-29-2016, 02:44 PM
stefuel
stefuel's Avatar
I'll tell you what I "think" it is. My GM pickup started doing the same thing. What I found was that the foam seals on the various doors in the A/C system ( the doors that regulate heat/cool and direction the air blows out) was falling off and no longer sealing tight. This would cause a air rushing sound. My pickup was out of warranty, so I had to pull the thing apart and fix it my self. Not for the faint of heart. Set the fan to high and check for air coming out of outlets that it shouldn't. I have not had a Vettes hvac box apart, so I have no advice. Only other thing I can think of is a bad actuator that is not closing a door all the way. The door responsible for recirculation/outside air would probably be the loudest.
Old 05-29-2016, 09:05 PM
meanjoe
meanjoe's Avatar
I'm going to go try this as soon as I figure out where it is and how to get it out.
Old 05-30-2016, 09:38 AM
Wass
Wass's Avatar
St. Jude Donor '09-'11
To AC/Heater fan noise
Old 05-30-2016, 10:05 AM
dr_whigham
dr_whigham's Avatar
^^ Thank you for that pic ^^
Old 05-30-2016, 10:26 PM
meanjoe
meanjoe's Avatar
So thanks for the directions. I found the location and found out that the cover plate to this filter was only half on and one of the clips that is supposed to hold it there is missing. Went to Autozone and they sold me an STP filter for it. So we all know how that goes......Get it home take out the old match it up to the new and it's a 1/4" narrower than the stock one. Don't fit good. So returned it and the dealer has a new OEM one waiting for me to go get in the morning. $36.96 plus tax with my discount. I hope this quiets things down. Below is the old one, I'll be checking this more often from now on.
Old 05-30-2016, 11:08 PM
User Omega
User Omega's Avatar
That is pretty nasty. It definitely needed replaced either way. With the vehicles I have owned I've found it to work out pretty well to replace them every 20k unless you live in an area where there is excessive dust or construction.
Quick Reply: [Z06] AC/Heater fan noise
